Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 09-30-2014, 03:39 PM
02 Super Duty Guy's Avatar
02 Super Duty Guy 02 Super Duty Guy is offline
02 Super Duty Guy is starting off with a positive reputation.
Why wont my center caps go on my wheels anymore?
I have an 02 with the 9 hole chrome clad steel rims. my center caps will not go on my rims anymore. its almost like there hitting the rim itself, but they aren't. one side will go on, but when I hit the other side, the first side pops back off. can the chrome "tabs" in between the lug nuts be at fault? when I tighten the lugs they seem to go behind the tabs a little. and I can see how that would hold the caps from grabbing the lugnut. any ideas? am I the only one with this problem?
Old 09-30-2014, 08:16 PM
damn 105 views and no one knows? lol im screwed
Old 09-30-2014, 08:41 PM
Lou Braun Lou Braun is offline
Lou Braun has a good reputation on FTE.Lou Braun has a good reputation on FTE.
If your covers are like mine, those tabs go over the lug nuts and lock in place with a firm shove.
If the tabs are bent, I could see one pop off.
Lou Braun
__________________
'06 F350XLT 4WD 6.0
'03 Cat MT295 4WD w/16 speed
Old 10-01-2014, 10:16 AM
speakerfritz's Avatar
speakerfritz speakerfritz is offline
speakerfritz is starting off with a positive reputation.
my caps engage the stud threads...if your lug nuts are not stock...check that.
__________________
Hellwig 7677Rear Sway Bar; Hellwig 61904 Pro-Series Helper Spring with Silent Feature; 2 ofRancho Suspension/Monroe RS999046 Rear Rancho RS9000; 2 of Rancho RS999042RS9000XL Series Shock; Rancho RS98510 Steering Stabilizer Kit; Dee Zee DZ43203Tailgate Assist Shock
Old 10-01-2014, 11:08 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
There is a flange on each lug nut. The clips that are in the center caps hang onto to those flanges. Make sure the clips are in good shape and in the right place.
__________________
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." (Thomas Jefferson)
Old 10-01-2014, 01:34 PM
Aero750 Aero750 is offline
Aero750 is starting off with a positive reputation.
I also have an 02 and had the same problem especially while towing. I put silicone on the tabs of the center caps, not much I did 2 tabs on each across from each other and they have not come off since. I did this I think back in April
Old 10-01-2014, 02:01 PM
r2millers's Avatar
r2millers r2millers is offline
r2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to beholdr2millers is a splendid one to behold
Quote:
Just curious... Why would towing make a difference with the hubs staying on?
__________________
Bob and better half
As my brother reminds me regularly... "Life is not a spectator sport."
2007 F-250, PSD, SW, CC, LB, 2 WD, 85k, coolant filter, DashBoss, 1999 Expedition 5.4 319k plus, 32' CrossRoads CrossTerrain 5th wheel Toy Hauler, 24' Chaparral Villain lll 598 ci
Old 10-01-2014, 02:06 PM
Quote:
I have no idea. But that is when they would come off When I wasn't towing they would stay put lol
Old 10-02-2014, 04:02 PM
it weird though, everything is stock and the center cap wont go onto one wheel but then you go to the other side with the same center cap and it'll pop right on like its supposed to
Old 10-02-2014, 08:24 PM
Tony Lee's Avatar
Tony Lee Tony Lee is offline
Tony Lee is starting off with a positive reputation.
Have you tried swapping the caps over to see if it is the cap that is the problem, or the wheel
__________________
Tony LEE
Travel Photo Albums
Spotwalla Travels Map
Old 10-03-2014, 12:33 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a spectacular reputation.Yahiko has a spectacular reputation.Yahiko has a spectacular reputation.Yahiko has a spectacular reputation.Yahiko has a spectacular reputation.Yahiko has a spectacular reputation.Yahiko has a spectacular reputation.Yahiko has a spectacular reputation.Yahiko has a spectacular reputation.Yahiko has a spectacular reputation.Yahiko has a spectacular reputation.
Post a photo of the inside of the good and bad cap
then also one of the wheels.
Sean Click the image to open in full size.
__________________
Three Happy Cats "How do you eat an elephant? One bite at a time!"
Mods Blue Spring, High Idle(BCP), Coolant Filter,SCT from http://www.gearheadautomotiveperformance.com/
HFCM Drain Plug, Nav System, Leveling Kit, FIXED the Dead Backup Camera, HID Fog 3000K & Driving Lights 4300K
6.0l Forum Map : Ask me About It
Old 10-04-2014, 02:37 PM
fusefinder fusefinder is offline
fusefinder is starting off with a positive reputation.
I have the same problem. I have Warn Premium Manual hubs. Drivers fits perfectly, passenger had about a 6mm gap (hub is inset 6mm). Centercap doesn't catch both sides like the OP explained. Did the silicon, haven't lost this replacement yet but worried.
Old 10-06-2014, 05:26 PM
atom ant atom ant is offline
atom ant is starting off with a positive reputation.
I lost both of my rear center caps - twice - on the same bump in the road on I-25. I recovered 1, but it is a graveyard for hubcaps, and ironically 99 percent are Ford superduty!
Went into the field looking for 3, came out with 5.
I believe my issue was I had inflated the Dually tires to 80 psi rather than 60 (thinking of my SRW). I dropped pressure to 60 and tested several times towing and not towing and they seem to be hanging on.
Good idea about the silicone!
Old 10-11-2014, 11:35 PM
After reading your post about the studs I ,looked a little closer at mine and the center cap. I decided to take my right angle air grinder to the high spots on the center cap, smoothed them down to just above where the stud catches. Fits much better and the gap is down to about 2mm. Its been about a week and no issues yet, cant even pull it off have to use a tool now!
Thanks for the input!
__________________
2003 Ford F250 SuperDuty XLT Crew Cab 81" bed. 7.3L Diesel Auto Transmission. 225K miles and going.
Old 10-14-2014, 02:20 PM
Mystic_Cobra's Avatar
Mystic_Cobra Mystic_Cobra is offline
Mystic_Cobra is starting off with a positive reputation.
I've lost three rear caps of my 2015 dually in just the first 2 months of ownership. I replaced the first one my self thinking it was a fluke. Then kept losing them. I run the tires pressures as listed on the door always.
Fronts are fine. Rears are gone.
__________________
Jimmy
2015 F350 Platinum SCrew DRW 4x4 LB
1965 289 Mustang coupe, 1996 Mustang Cobra road racer, '98 Mustang Cobra DD
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Check your 18" wheel center caps! rdenis 6.7L Power Stroke Diesel 15 10-08-2014 12:06 PM
F250/F350 center caps firemanp 1994.5 - 1997 7.3L Power Stroke Diesel 8 10-17-2007 08:38 AM
Closed Lug nuts for 1997 F150 (12mm) schmidty_dog 1997 - 2003 F150 2 06-20-2007 08:24 AM
Hubcentric chrome lug nuts 12mm schmidty_dog Brakes, Steering, Suspension, Tires, & Wheels 0 06-12-2007 11:21 AM
chrome center caps 2fastrucks Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 4 04-24-2002 09:22 AM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
