Supercharger for f-350 with 5.4 engine
I have been trying unsuccessfully to find anyone in the country that has put a Whipple Supercharger on a F-350 with the 5.4 engine. My truck is a 2006. Super Duty 4x4. Virginia Speed which is a Hugh speed shop in our area has been calling everywhere to see if this can be done or has been done with some minor modifications. Can anyone on this forum point me in the right direction. Thank you so much, Bill
No reason it shouldn't bolt on. You will need a custom tune as Whipple doesn't have a tune for the F-350 and I would highly recommend you upgrade to 42 or 47lb injectors. Best price on them is found here http://www.blueovalindustries.com/en...el/en8390.html.
If your truck is an 8 rib belt/pulley set up (which i doubt) then you would simply need to use the Whipple pulley for 3.4 Lightning blower. I used this pulley when I did an 8 rib swap on my truck. Simple bolt on.
2003F-350SuperDty5.4
Modular V8 (4.6L, 5.4L)
11-24-2008 07:47 AM
Whippled04
1999 to 2016 Super Duty
11-16-2006 04:11 PM
