No disadvantage to using one. I had to top off my radiator here and there before I installed one. Now, it's never down. Plus, you can install some cool whiskey bottle or whatever.
Ok, I can understand the coolant going past the pressurized cap and going into the recovery tank. How does the coolant get sucked back back into the radiator? Does the radiator cap have a one way valve to let the coolant back in? Hmm.... Patrick
I just returned a Mr. Gasket tank today to Summit. Supposed to be polished aluminum but turned out to be chrome plated over something. Magnet will stick to it lightly so don't know if they can plate over aluminum. It had about 12 bubbles under the chrome. Brackets are a throw-away deal. I went ahead and ordered a Vintage Air from Summit which looks to have good mounts and I haven't seen any of there stuff that was junk!
TractormanBill
Yes, there is a vacuum release valve in the center of the cap. Whether you use a recovery tank or not, you have to have that or the radiator tank would collapse as the radiator cools. With a recovery tank, it lets water back in instead of air.
