2015 CCSB 6.2. 4.30s - Nowhere to be found
Yea, I thought for sure there would be a difference in the performance. The truck is old and tired.
After driving with 4.10s for a few years, 3.73s just made more sense for what I do. Its my only vehicle so I kind of went with a mix of comfort and towing the 4x4. That and I was going to go crazy having to wait 8+ weeks for the special order to come in, haha.
My overall recent experience with finding trucks with 4.30s was impossible. There were zero. Hell, I think I found the only CCLB 6.2 XLT in New England that isn't white on the lot.
Your 96' is not really relevent to my comments, different engines. The 99'up is what I was referring too, where you are looking at running around 2250 rpm at 65mph with 4.30s in OD on the older SDs. Newer trucks are even less rpm due to OD ratio and tire size.
Sounds like you are not getting into overdrive and/or you have TQ lockup issues. Overdrive ratio on the E4OD is .71.
True that. He did want a SRW didn't he?
If I were going to buy a new one I would still do it again like I did on a new 1999 and took the extended fenders off and made it a SRW that I could transform when I wanted in a couple of hours. I did it back then to get a Dana 60 front axle instead of the 50. I would want the larger ball joints that badly.
I gotta off topic this, WHAT? I had a 1997 F250 HD reg cab 4x4 5.8 and E4OD with 4.10 gears and even with the baby stock 235 tires I only turned 2150rpm at 65mph on the highway...... jumping up to a 285 74r16 dropped it to 2k at 65mph and that truck got a steady 11mpg and I drove that truck hard and fast!
galaxy S4 using IB AutoGroup
Edit: Found an old thread. Looks like they made such a beast.(I don't know why) Maybe Ford had a good number of left over C6 trans on hand.
https://www.ford-trucks.com/forums/1...g-problem.html
Who knows.
Thanks for all of the replies guys. I apologize for the apparent absence. I was out of town for a couple of days for work and didn't have a chance to get back onto the forum. I definitely want a SRW truck, I am just trying to decide between ordering a 6.2 with the 4.30 gears and buying a diesel that is already on the lot. I am not sure that I want to wait the 2-4 months for a truck, even if it is built exactly the way I want it. I think that the anticipation would drive me insane.
It has been suggested that I could buy a gasser with the 3.73 gears and get it regeared. I am not strictly opposed to that, but it only works for me if the GCWR isn't actually posted on the door sticker along with the GVWR. I would really hate to be towing that 11k pound trailer and have something happen only to have the insurance company come back and say that they wouldn't cover anything because I was over my GCWR.
Can you guys with both the 3.73 factory gears and the 4.30 gears look at the door stickers on your trucks to see if the GCWR is posted there, and if so, what is posted in each case?
Here is the 2015 Tow Guide.
http://www.fleet.ford.com/resources/...Tgde_May19.pdf
3.73 GCWR = 19,000 lbs
4.30 GCWR = 22,000 lbs
If you get a regear at the Ford dealer ship you are easily over $2k+. You can get better prices from a non dealer shop but they will most likely use non OE gear sets. Not a bit deal if they are quality parts.
You are better off ordering what you want and waiting IMO but th edecision is your.
#28
CAFE averages
"I find it odd that all of the gassers are coming with the 3.73 gears, but maybe others are more concerned with fuel mileage than towing capacity?"
The manufacturer needs to keep their CAFE averages high.
Weight rating on door does not matter to insurance adjuster as he records the VIN with the "as built" information. Trying to get it recertified by changing gears is a burden of proof you may not want to toy with.
Even today, patience is still a virtue.
#29
Denny
