98 sohc to 96 dohc mark knock sensors
Old 09-29-2014, 10:37 PM
#1fordguy's Avatar
#1fordguy
#1fordguy is offline
Hi any help would be very much appreciated.So I'm all done with the wiring except the knock sensor!!OK so I know these sensors a very crucial to the motors life.My sohc has one sensor in mid block and one on the on side under head with a two pin plug for each one.The dohc has one wire going to both sensors which are under each head with a three pin plug.The color code on the wires at the harness are the same except one wire a solid green.They both have a common gray w/red stripe.My sohc harness wire are front engine gray and red and yellow and green.Rear harness plug is gray and red and yellow and red.OK dohc knock sensor plugs drive side gray and red which are same as rear harness plug.The passenger side is gray and red and solid green.So I think I can just wire the matching colors to harness color except the solid green had no mate.Can any one help with this issue please and thank you..
Lockholder
10-28-2018 02:25 PM
DasKroger
Electrical Systems/Wiring
08-12-2014 11:54 AM
justforkicks
11-18-2011 08:21 PM
sbraatz
08-27-2007 04:23 PM
Quick Reply: 98 sohc to 96 dohc mark knock sensors
