My cruise control sensor on the master cylinder started leaking brake fluid-wich i believe was a recall so i went to parts store bought a new sensor that came with a wire to plug the new sensor in Now my cruise control isn't working Any ideas on how to fix this?
ok i took out the link with the fuses it had two both were good and connected it without that link still nothing cruise control was working fine before this problem
My cruise control sensor went out a couple of months ago and my mechanic replaced it and mine has worked fine ever since. Did you check the brake pedal to see if the there could be a connection there?
