Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Fuel pump relays location
Old 09-29-2014, 08:12 PM
Maroen Maroen is offline
Maroen is starting off with a positive reputation.
I have searched this site and all locations listed are not on my truck. I have a 1990 F-350 with a 460 and dual tanks. It was done over by Trail Wagons out of Yakama, Wa. I can't for the life of me find the relays! Not under the hood or any that I can see under the dash by the fuse panel. There are some questionalble wires/box by the radio area, but seem to be a VERY hard area to access. Any ideas???? Oh and the reason I suspect it is the relay and not the pump is that I came off the Interstate and it started to run funny and drove it 2 miles to work and when I got off work it wouldn't start using the front tank, but started from the fuel in the rear tank...... Thanks, Mark
Old 09-30-2014, 08:15 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
If it ran on either tank it's not the relay since the same one powers both tanks, it could be your dash switch but that isn't common it's far more likely the pump is bad. The relay should be behind the airbox on the drivers side inner fender.
__________________
Paul (Conan) O'Brien
2006 E250 4.6L 4R75w 4.10, 2004 Ranger 3.0L 5-sp X-cab 4.10, 1994 Ranger 3.0L 5-sp x-cab 3.45, 2004 Subaru Legacy 2.5L 5-spd
1996 Kawasaki ZX11D, 2002 Honda VFR800,
Old 09-30-2014, 08:51 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
As Paul said the fuel pump relay is OK but it should be in the location of the photos below:
Click the image to open in full size.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
Old 09-30-2014, 12:34 PM
Nope no relay there. I do have a heavy duty tow package and there is a relay for that, but where it says Fuel Pump Relay - there is nothing there.
Old 09-30-2014, 02:54 PM
Conanski's Avatar
Are they laying on the wiring on the inner fender below that?
__________________
Old 09-30-2014, 09:55 PM
Thanks for the replys, but still can't find any fuel relays!!! If what was stated before about only 1 relay for both pumps, then I guess it has to be the front pump... Wow this really sucks as I live in a RV park and they don't allow working on vehicles here. Guess I'm gonna have to do it incognito here to do it.
Old 10-01-2014, 02:55 PM
Not that I can see. Just the relays for the trailer package and the EEC. Unless the trailer package relay is actually the fuel pump relay?
Old 10-01-2014, 07:19 PM
Conanski's Avatar
A '90 truck would not have been prewired for a trailer package so if you have 2 relays there they are for the EEC and fuel pumps.
__________________
Old 10-01-2014, 08:10 PM
subford's Avatar
The one with the green bottom is the fuel pump relay.
But we have already stated that there is nothing wrong with your fuel pump relay as the pump in the other tank will run OK. This is true if you have factory wiring and someone has not wired around the fuel pump relay.
__________________
subford@gmail.com
Old 10-02-2014, 03:31 AM
Well, thanks for all the info guys. Guess I gotta start saving up for a new fuel pump! I didn't realize that they used 1 relay for both pumps. Anyone know how long it takes to change the front fuel pump? I do have an electric impact gun, so can remove bolts/nuts pretty fast. Thanks again, Mark
Old 10-02-2014, 06:49 AM
subford's Avatar
It will take about a half an hour to an hour once the bed is pull to the rear or removed to expose the top of the tank.
I just did one yesterday.
Getting the bed bolts out is the hard part.
You can drop the rear tank to change its FDM (pump) but getting to the front tanks strap bolts is very hard without removing the drive shaft for the nuts and getting hold of the head of the bolt on top side is also very hard.
It is a lot easier to just move the bed back or take it off.
Note your problem can still be the selector switch or the wiring to the pump and not the pump.
In the diagram below you have the bottom relay.
The top relay was to show how to convert to the newer stile relay if you have bad relay sockets or bad wiring under them.
__________________
subford@gmail.com
Old 10-05-2014, 01:00 AM
Thanks for the info Bill. Crap, I have been using the truck as a rolling storage shed and have a bunch of stuff in the bed and also a bed liner. And a shell on it too. I will look at the wiring before I get a storage unit for my stuff. Hopefully it's the wiring!!
Old 10-08-2014, 12:31 PM
Also, I see that the switch is screwed onto the faceplate and I need to get the ***** for the light switch and wipers off and remove the faceplate. After that is it easy to test the switch? Thanks, Mark
Old 04-20-2015, 03:55 AM
Well, come to find out it was the pump. Ordered one from Rockauto.com and they didn't list it correctly and I got the wrong one. That place is screwed up! I will never do business with them again! Anyway got a used one and it works great..... Thanks to everyone for their help and advice!
Similar Threads
1995 Rockwood motorhome F350 chassis cendres1234 Super Duty & Heavy Duty 2 09-23-2013 12:01 PM
2000 F250SD Fuel Pump relay location nomad27 Modular V10 (6.8l) 18 01-21-2013 11:54 AM
1985 E350 Cargo Van No Fuel batmmannn 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 07-30-2010 07:09 PM
Forgive me, but here's a Geo Tracker EFI ? Traderjoe28 General Automotive Discussion 4 07-21-2006 03:33 PM
'91 F-150 REAR Tank won't work. Johnks4x4 1987 - 1996 F150 & Larger F-Series Trucks 6 10-20-2004 01:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
