6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
After repair issues
Old 09-29-2014, 04:01 PM
dman255's Avatar
dman255
dman255 is offline
Information Junkie
After repair issues
I just got my truck back from shop. Things done were injectors, injection pump, rocker arms, head studs and head gaskets, ccv mod, egr delete, and 6.0 manifolds and new up pipes. The issue i'm having is prior to going in shop I had no trans issues at all. Like it never even hiccuped. Now i can't take off without it kicking while trying to go into third then throwing these codes= P0766 & P2703. I just payed an arm and a leg on this truck and now this. Help!!re
pair
Old 09-29-2014, 04:58 PM
muntu's Avatar
muntu
muntu is offline
P0766 Shift Solenoid D Performance or Stuck Off
P2703 Transmission Friction Element D Apply Time Range/Performance
Old 09-29-2014, 05:23 PM
dman255's Avatar
dman255
dman255 is offline
Information Junkie
Right that's what my tuner said. It's just strange that it goes in no trans problem comes out with a trans problem. Is there anything i can check that could cause those codes or is it trans taking a dump
Old 09-29-2014, 06:45 PM
slowmans's Avatar
slowmans
slowmans is offline
Did you talk to the shop that did the work?
Old 09-29-2014, 07:30 PM
dman255's Avatar
dman255
dman255 is offline
Information Junkie
Yeah i called them about five min after i left. He said clear codes probably part of the relearn. I cleared them. I've done the relearn a bunch of times before and this never happened. Called him again he said maybe power difference but i'm running the 210 tune I've run the 300 tune before with no issue. So i'm sure it's not too much power. I'm going to take it back in tomorrow. Just wanted input from you guys. Don't really want to take it in and find out i need a new trans or something stupid.
Old 09-29-2014, 08:49 PM
78fordman's Avatar
78fordman
78fordman is offline
Have you changed the Trans fluid lately? Is it ford sp or lv? Wrong fluid type in a 5r110w will cause sticking solenoids. It has nothing to do with the relearn.
Old 09-29-2014, 10:02 PM
dman255's Avatar
dman255
dman255 is offline
Information Junkie
I'm at 105,000 and i don't know if the fluid has ever been changed. I bought it at around 60,000 miles. The sp fluid is not available anymore. I've been planning to get it changed or flushed before the hpfp went out, but have read that a flush isn't recommended? I bought fluid today to drop pan and change some of it then do it again in 100 or so miles. Nobody in town had a filter though.
Old 10-03-2014, 10:12 PM
dman255's Avatar
dman255
dman255 is offline
Information Junkie
Ok i got a modified solenoid from empire performance engineering. Put it in and no difference. delayed going into reverse and still slams like video. I babied and got it to go into overdrive sometimes it slips terrible and the next it holds?? After codes go off I can't get it to slip at all gears 1-4? Any info would be greatly appreciated!!
Old 10-04-2014, 10:59 PM
78fordman's Avatar
78fordman
You changed shift solenoid d or the pressure solenoid? Aftermarket companies make a modified pressure solenoid but I have never seen a modified shift solenoid.
Old 10-05-2014, 12:11 PM
dman255's Avatar
dman255
dman255 is offline
Information Junkie
Yes I changed solenoid D here's the link to the one I changed.
Empire Performance EPE-5R110S Modified Direct Clutch Solenoid
My trans fluid I drained out was pretty dark and smelled a little burnt. Although it did have 105,000 miles on it. I'm leaning to a different trans. I can't get it to shift right into 4 it slaps hard a few times then throws codes and holds 4th. It really doesn't hold 5th well if i can get it to even get there. If anyone has something else i could check that'd be great. Otherwise maybe some input as to what trans i should put in. I've been without the truck for over 2 months now. I really need this truck back and running. Thanks for all the input so far.
ChunderDownUnder
03-11-2013 06:04 AM
Talyn
Virginia Chapter
03-09-2009 09:27 AM
randomhero1172
04-27-2008 01:56 PM
LUMBERMAN
01-14-2008 09:19 PM
coon9
04-08-2006 10:48 AM
Quick Reply: After repair issues
