wiring diagram for 1993 F-150 - Ford Truck Enthusiasts Forums
Old 04-16-2002, 08:53 PM
arapco arapco is offline
arapco is starting off with a positive reputation.
My truck has developed a short affecting the entire rear lights,ie: signal, tail lights, brake lights ( of course). The connections are all sound, in fact the backup lights do work.
I wonder if anyone has a wiring diagram that they might fax to me so that the trouble shooting will be made easier and intelligently.
I would appreciate this document so that I can work the issue tomorrow.
email arapco1(No Email Addresses In Posts!)
Thank you in advance.
Old 04-17-2002, 01:39 PM
mantta's Avatar
mantta mantta is offline
mantta is gaining momentum as a positive member of FTE.
I have a drawing, let me see what I can do with my digital camera and if it turns out I will email it to you.
Old 04-17-2002, 09:10 PM
Larry, I want to thank you publicly for the schematics you sent me. I also received a set of electrical schematic drawings from R. Smith and with the combination was able to determine the root cause.
I found, much to my satisfaction, the short, not in the harness, but in the trailer/camper harness connector. This apparently had been crushed during the replacement of the rear bumper required after the truck had met an oak tree.
Thank you for your speedy response. I hope that I may be as helpful to someone in need of aid.
Ron
Old 04-20-2002, 04:42 PM
mantta's Avatar
Old 04-20-2002, 10:50 PM
Post wiring diagram for 1993 F-150
I am here again to report what the root cause of the short and the resulting damage.
I had earlier indicated the problem source as the camper connector, however after checking the crushed connector, I found no electrical damage but notice a couple of wires that were apparently not connected to anything. These disconnected wires happen to be the result of the previous owner having U-Haul make one of their wondrous connections into the brake/turnsignal, running light and remote battery charging wire with one of those splicing devices that they are so apt to use. The wire that had completely been sawed through happened to be the always hot camper battery charging wire which ultimately made contact with the bumper bracket.
To make matters worse, the overload on the flasher unit caused the heater to burn out and remain in close position.
Nice, huh, Had fun tracing and correcting but that would not have been possible if it wasn't for the help of the aforementioned members.
Thanks again.
2007 Expy trailer lights not working joiseystud 2007 - 2014 Expedition & Navigator 7 09-18-2011 12:32 PM
66 F100 wiring diagrams skyhawc 1961 - 1966 F-100 & Larger F-Series Trucks 5 11-10-2010 03:33 PM
Interior lighting wiring diagram for '90 FLJ Electrical Systems/Wiring 2 06-20-2009 06:47 AM
'66 wiring diagram needed bmwfreak 1961 - 1966 F-100 & Larger F-Series Trucks 6 04-19-2009 01:40 PM
changing spark plugs on mazda b4000 mldx20 Ranger & B-Series 2 07-05-2003 08:01 PM
Tags
150, 1993, 50, diagram, diagrams, e150, f150, ford, fuel, injection, pickup, radio, troulbeshooting, truck, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
