blinker issues
When the signals quit, do the hazard lights and flashers still work?
Do all of the turn signal lamps work or just fail to flash (cycle)?
Review the circuit diagrams and find the likely culprit. Post back your findings.
on
jk, any update on this?
edit: I found these how to read schematics: http://www.wikihow.com/Read-Schematics
Also, some more how to's: http://www.popularmechanics.com/cars...enance/4314662 http://www.ask-the-electrician.com/h...ring-problems/
Tools you might need: a decent Multimeter and/or a testlight but mostly your brain is your best tool. If it helps, think of each wire as a pipe of electrons and flows about through them, through your load (lights) and then through the chassis (ground). (the wrinkle is that electrons flow from the negative to positive).
Also I really hate these light sockets And would be the first place I would look for leaking blinker fluid
You forgot the part numbers for Blinker Fluid!
edit: I found these how to read schematics: How to Read Schematics: 5 Steps (with Pictures) - wikiHow How to read and use your wiring diagram - YouTube Hope this helps!
Also, some more how to's: How to Diagnose Car Electrical Problems by Tracing Voltage Drops - Popular Mechanics How to Fix Car Wiring Problems
A pipe full of electrons? Way too complicated.
As an electrician, I always think of electricity as plastic tubes full of smoke. As long as the smoke stays in the tubes, all is good.
But we all know what happens when the smoke leaks out, don't we?
Seriously, Zark-eh offers some very good advice. Don't try to over complicate things. Take one wire at a time and prove it out. Make sure all connections are clean, tight and corrosion free.
Ryan Cunningham
10-26-2016 06:24 PM
magnium1
10-20-2011 03:26 PM
fokkersauras
01-10-2006 01:04 PM
