Transmission Problem, Delay in Engaging Drive
Howdy all, been a while since I was able to post, good to be back.
Have been out camping for the last 3 weeks, and had this happen twice, shifting from reverse to drive, there is a 5 second or so delay before the transmission engages. Everything runs perfect otherwise with the transmission. My last flush was 50k miles ago, so I am coming do for another flush(I did the full Mark K. flush when i got the truck, as well as 50k ago). I just joined the 200k club on the truck on my way back.
All that said, any ideas on what to do next. i was going to go ahead and do the flush again this weekend, anything I should look at, tighten up, replace that might be causing this? Or am I do for a tranny rebuild/replace?
thanks much, Tom
thanks much, Tom
Torque spec
Finally started this project last night. The bolts under the column are tight, so I started the fluid project last night, pan off, and it is draining/dripping for the day while I work.
Question is, what should be the torque setting for the feed bolts, as well as the valve body when I reinstall those items?
Thanks much, Tom
Thanks much, Tom
on
Feed Bolts= 12 ft-lbs
Valve Body Bolts= 100 in-lbs
Here is also a picture of where the check ***** go. If you lower the separator plate carefully, they will stay in there respective holes on the plate. Also, there are 2 VB bolts that attach the Lower VB to the Main VB. The rest go through into the Case. Leave those attached and lower the 2 VB's together as a unit.
JoeHarbourJets
10-28-2011 08:37 PM
ajorn
01-20-2010 09:45 PM
