95 F250 7.3 Turbodiesel 4x4 Tcase Differential Fluid Change Recommendations
I have a 95 F250 7.3 turbodiesel 4x4 with a manual transmission. I would like to change the fluid in the transfer case and in both the front and rear differentials. I would appreciate any recommendation on type-of fluid and quantity, along with any tips on performing a smooth change.
Thank you
Thank you
Transfer case takes ATF. Aprx. 2 quarts, IIRC. Like any bath oiled case, you fill it to the bottom of the fill plug. There's a fill plug and a drain plug. Don't overtighten either one (don't ask how I know .
Diffs take any good quality gear oil; synthetic is always a good choice. If the rear is limited slip (axle code C5 or C9), it should get a friction modifier additive; however, synthetic gear oil typically doesn't require the additive.
Rear diff, you loosen the cover bolts a little, loosen the LOWER bolts a little more, put a WIDE pan under it, pull the bottom edge outward a little bit 'til it drains. Fill plug is on the forward side of the diff.
Front diff, you either have to take the whole front axle apart (since the one "arm" doubles as the diff cover) or siphon it out through the fill hole.
Thank you for the response. Can you recommend a good brand? I found this one: Castrol-Transmax-ATF-full-synthetic-multi-vehicle-transmission-fluid on A-Zone's website but it doesn't seem to fit with Mercon V; the fluid says it's compatible with Mercon LV.
On another note, I stopped at my local Ford dealership a couple of days ago and gave the rep all of the specs of my vehicle. He came back with the Mercon V ATF saying it was appropriate for use as fluid on the manual transmission of my 7.3; it seems he was full-of-it and that is a little disturbing.
Thank you for the help
KyEdExpedition
1997-2006 Expedition & Navigator
11-23-2006 07:25 PM
geoaigel
1978 - 1996 Big Bronco
17
03-23-2006 09:21 PM
