Gas Filler
For tanks with a filler neck only and no vent tube I run one of these off a 3/8" nipple from either the filler tube or top of the gas tank. It is a one way check valve that lets air in but fumes cant get out, they were used on 1985-1995 camaros and firebirds. They may not be easy to find new but there should be plenty of those cars in the junkyards. There should be one way check valves available aftermarket as well or you could use a rollover valve which works the same way but may need to be mounted to the top of the tank. I woudlnt use a gas filter only because the gas fumes will always be dumping around the car.
Nobody wants a garage smelling like gas.
- allows air out of the tank when filling so it doesnt back up and spit back (larger the vent hose the faster you can fill the tank)
-allows air into the tank when the engine is running so a vacuum isnt formed which wants to collapse the tank and shut off the fuel supply.
I have done it both ways, with a 3/8" vent hose tapped under the cap and with the larger 1/2" vent line to the tank depending on the tank design. In this case with that sealed cap the 3/8" hose tapped into the filler tube under the cap will allow air into the tank when the engine is running and the cap is sealed which will keep the tank from collapsing. The cap looks wide open so air will come in from the outside through the open cap when filling up.
The other picture of the filler with the 1/2" vent line is a "modern" sealed system piece and the vent normally connects to the top of the tank at the sending unit or a fitting on the tank. This allows air to excape the tank during fill up (modern small hole in the gas fill to keep fumes from excaping when getting gas). Air to the tank when the engine is running comes through a small vent line hooked to a charcoal canister.
Hope that wasnt too confusing, just have to remember there are actually two ways air has to get in and out of the tank. One for engine running and the other for when filling the tank.
As an example this is the gas tank in my 47 cadillac. You can see the port for the vent to hook up from the filler tube. This allows air to push to the top of the tank during fill up and vent out into the filler neck.
Air for engine running comes from a 1/4" line that connects to the charcoal canister through a check valve on the canister. If you dont run a canister the check valve would go on that line.
Older cars with the wide open gas filler tube didnt need this system, just a vented cap to let air in when the engine was running and air out of the tank when getting gas through the huge open gas fill tube. I prefer sealed systems and I type too much!
Both trucks I am building now will get the larger 1/2"' vent line to the tank and a 1/4" vent line through a charcoal canister.
There are so many options for venting that I'm not really sure what I need...
This is the tank that I installed:
It has a bung for venting but I assumed it would be for the fill vent but now I think its for the running vent???
The flip cap is vented. Does that mean I don't need another vent for running, just need one for filling?
if the cap is vented you only need the fill vent tube into the fill neck. Make sure the fill vent opening is slightly below the top of the tank so it spits back with a little air space still in the top of the tank. Otherwise if you shoud fill up on a cool AM/from cool underground tank and park in the hot midday sun the gas can expand and push past fuel pump/carb.
Since the hole is in the top of the tank do I need one of these?
1948-79 Ford F-100 Rollover Vent Valve, In Tank, 1/4 Npt
I'm not sure how to add the filler vent to the fill tube. Can I just drill and tap a hole in the filler neck or do I use an hose adapter to connect the vent tube from the tank? Is 3/8" hose big enough for the vent?
If you are using a vented gas cap and a wide open filler neck (larger than the gas station filler nozzle) then there is nothing more you need.
The vented cap will allow air into the tank while the engine is running.
The large gas fill neck will allow air out of the tank while filling up.
Nothing else needed, if you were running a sealed gas cap you would need to do more work. You can cap off the other ports on the tank that you do not need.
