Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Lowering Kits
Overview of popular modifications to customize your truck
Twin I Beam Pivot Modification
I had thought about this, but never got beyond measuring stages. My plan was more elaborate with grafting a 87+ F250 front on with a 2-3 inch Z, doing the pivot relocation, and moving the steering box up to match the pivot plus Z. The front steer made the craziness possible.
One thought I had is that I would now have to use a off-set or just longer hair pin to avoid pulling the beam to far back on compression.
Also you may have to cut out a portion of the cross member where it turns up to avoid a solid bump stop.
With the instalation of the Mark VIII motor I have a lot of clearance under the oil pan so I am going to notch the cross member for I-beam clearance
codafisler
04-23-2012 10:18 PM
bigtiny2020
12-15-2009 12:57 AM
