Low beams don't work but high beams do
Old 09-28-2014, 09:12 PM
dee_011's Avatar
dee_011
dee_011 is offline
Hi I recently installed new halo HID headlights in my 2003 f150 with HID bulbs and ballast the passenger side worked and the drivers side didn't nth lights wired exactly the same. I switched everything from the passenger to the drivers side still nothing I switched everything back to passenger side and they don't work now. I tired regular bulbs in the passenger side an it worked then on the drivers side and it worked for a split second and went out and then I retried t on the passenger side and it worked for a spilt second and went out a now neither are working. I checked all the fuses and their good. Any suggestions to what the problem could be? Thanks in advance for the help.
Old 09-28-2014, 09:23 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Check the common ground points for these circuits.
Good luck.
Old 09-28-2014, 09:45 PM
dee_011's Avatar
dee_011
dee_011 is offline
Good luck.
I have no idea where those are located lol
Old 09-28-2014, 11:27 PM
Bluegrass 7
Follow the black leads.
You can even supply temporary grounds as a way to see if loss of ground is the cause.
Make good use of voltmeters and Ohm meters to do supporting testing.
Good luck.
Old 09-29-2014, 06:25 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
The left and right low beams each have their own fuse. Check fuses F26 & F28 under the dash.
If the fuses are not blown, check the interface between the original wiring and whatever clusterf**k came with the HID kit. You may have gotten bad connectors that damaged your original ones when they were plugged together.
Old 09-29-2014, 04:55 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is online now
I would add a jumper wire from the negative side of battery to the black wire in the plug at one light.. Intermittent operation is often a bad ground.
dx3
1999 to 2016 Super Duty
20
01-28-2018 03:22 PM
DeadFife
04-28-2017 07:12 PM
CelticFoot
03-23-2016 07:27 AM
comertrucks
1997 - 2003 F150
08-28-2006 12:03 AM
Quick Reply: Low beams don't work but high beams do
