Pros & Cons of radiator recovery tank?
Old 09-28-2014, 02:38 PM
tractormanbill's Avatar
tractormanbill
tractormanbill is offline
tractorman
I have a stock 302 with aluminum radiator, electric fan, AC and wonder if I should put a recovery tank on it.
TractormanBill
Old 09-28-2014, 04:00 PM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
Closed system keeps the radiator completey full and eliminates spilling coolant unless you overheat. I cant see of any disadvantage.
Old 09-28-2014, 05:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Also reduces oxygen available to the system for corrosion. Go for it! Generally the tank needs to hold 5% of cooling system capacity.
Old 09-29-2014, 05:43 PM
rhopper's Avatar
rhopper
rhopper is offline
No disadvantage to using one. I had to top off my radiator here and there before I installed one. Now, it's never down. Plus, you can install some cool whiskey bottle or whatever.
Old 10-02-2014, 12:43 PM
41505379's Avatar
41505379
41505379 is offline
how recovery work?
Ok, I can understand the coolant going past the pressurized cap and going into the recovery tank. How does the coolant get sucked back back into the radiator? Does the radiator cap have a one way valve to let the coolant back in? Hmm.... Patrick
Old 10-02-2014, 12:52 PM
tractormanbill
tractorman
I just returned a Mr. Gasket tank today to Summit. Supposed to be polished aluminum but turned out to be chrome plated over something. Magnet will stick to it lightly so don't know if they can plate over aluminum. It had about 12 bubbles under the chrome. Brackets are a throw-away deal. I went ahead and ordered a Vintage Air from Summit which looks to have good mounts and I haven't seen any of there stuff that was junk!
TractormanBill
Old 10-02-2014, 12:58 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Yes, there is a vacuum release valve in the center of the cap. Whether you use a recovery tank or not, you have to have that or the radiator tank would collapse as the radiator cools. With a recovery tank, it lets water back in instead of air.
berry1234
09-17-2013 03:03 PM
cajunsuperduty
07-10-2011 07:02 PM
Innovative Detailing
11-20-2006 11:10 AM
Stavid
Aerostar
04-12-2005 08:27 PM
dongc1
07-18-2004 05:27 AM
Quick Reply: Pros & Cons of radiator recovery tank?
