Heater Contro Valve Set Up
1968 F100 4x4
Currently I do not have my heater control valve installed. I have the one hose running from the water pump to the heater core and the other hose runs from the heater core, to the carb spacer and then to the single nipple.
I would like to have the hoses running to both the carb spacer and the heater control valve/heater core. In order to do so, I would need to install a double nipple, but I can't find one. I am going to make a run this week to a salvage yard to search for one.
If I can't find the double nipple inlet, would the following set up work or would it create it's own loop and reduce heater core flow?
1 hose from water pump to heater core.
1 hose from heater core to a T fitting - running to carb spacer and control valve
Out of carb spacer to a T fitting - running to single the nipple and back to control valve
vidaliaman
12-04-2017 06:29 PM
karljay
29
01-24-2017 08:29 AM
james gang 1001
09-04-2010 09:58 PM
68horses
10-16-2007 10:12 PM
