Loose Front Outer Axle on 2006 F250
#31
On another note.....
The slightly loose LH Upper Ball-joint is bothering me BUT iam not ready to put the cash into the full tear-down yet.
If I just buy a "cheap" Upper for now (plan on full proper repair/upgrade after Tax return).
Is it possible someway to change that Upper without tearing everything apart, basically beat the old one out.
Iam not sure if the new one can be finagled in there some redneck way with that darn axle shaft in the way
#33
Ok with the noise I hear (even though Hub seems tight) it would seem I need to replace the RH Hub & considering the truck has 125k Iam sure the other side wont be far behind.
If I have to spend $1,500 on the front end of this thing, I would rather get rid of the Ford crap & upgrade to one of these SpynTec Kits.....
99-08 Ford SpynTec Overview | Spyntec Industries
What do u guy's think
#34
And I just posted in another thread about the same issue, seems because the weight of the passenger side axle shaft it kills the big pressed on bub seal and once that starts to go it makes play and noise at the unit bearing. My 2004 has been doing it and ive been taking it apart and reinstalling it for a few months now..... whenever my 126k original unit bearings start to show signs of failure dynatrac will be getting a call from me
galaxy S4 using IB AutoGroup
#35
#36
The lower BallJoint has a large clip underneath but the upper does not, either way they both are designed to be pressed in/out & while I was hoping to just beat the Upper one out & installing a new cheap unit temporarily.
That idea is not happening because there is 1.5 inch's of Ball-Joint Body & only 1 inch of space between the Knuckle & Axle Shaft
#37
#38
#39
#40
only issue I was told with the SpinTec and DynaTrac conversions is their replacement parts are proprietary. So if you do have a bearing failure you must use their parts. They are much more expensive and so buying spares ahead of time just adds to the cost of converting
#41
#43
Tax-Return came in
I just ordered all this (Raybestos brand)...
2 Hub Assembly's (pn 715081)
2 Lower BallJoint's (pn 505-1181)
2 Upper BallJoint's (pn 500-1048)
& a OTC Knuckle Seal Installer (pn 6697)
I know I need 2 Knuckle Seals & 2 Axle Dust Seals (the seal on the end of the axle tube thats always flopping around on our trucks).
I heard theres an updated version of those Dust Seals
What am I missing (besides say U-Joints)
Anyone have "proven" P/N #'s on those Seal's for my 2006 F250
#44
The update axle dust seal is brs 170
I believe there is a gasket for the hub, and there is an o-ring that goes on the hub/bearing ( the new hub/bearing should come with this ).
I didn't replace the knuckle seal but wish I would have.
You need to seal it back up tight so there will be no vacuum leak when you use the auto 4x4.
#45
I always replace the knuckle seal whenever I tear the front apart. It prevents debris from fouling the assembly as well as holding vacuum. For the work and price going into there it's worth the $30 or so for peace of mind.
