Help Best Possible Radiator
Hellooo. I Recently bought a 1976 F250 Ranger, with a 390 in it. The 390 has basically all 460 parts, it's cammed, NOT THE ORIGINAL ENGINE. Originaly had a 360 in it. The radiator was brittle and leaking. Time for a new one. I heard they run hot? So because of this i want to know the best possible radiator i should get. Period.
first off, the 390 and 460 do not inter change parts, id go with something along the lines of a good after market alum one,maybe a griffin or a howe
Aluminum Radiator by Howe.
Be aware that 1973/78 F100/350's with round headlamps use TWO different radiator supports.
One was only used with the Super Cooling Radiator, because it has a larger opening radius.
Super Cooling Radiator has a HUGE top tank, it's wider and deeper than the other radiators.
1973/76 F100/350 360/390 & 460 Super Cooling Radiator (D3TZ-8005-G): 24 11/16" high x 24 1/4" wide, core is 2 5/8" thick.
Fan shroud was also installed on these trucks with or without a Super Cooling Radiator.
1973/76 F100/350 360/390: Super Cooling Radiator uses a different shroud (C7TZ-8146-B) than the standard/xtra cooling & A/C radiator shroud (D3TZ-8146-C).
1973/79 F100/350 460's with Super Cooling Radiator use a different shroud (D3TZ-8146-D).
These shrouds are reproduced by Carpenter, which uses these Ford part numbers in his catalog, also lists their dimensions.
Hellooo. I Recently bought a 1976 F250 Ranger, with a 390 in it. The 390 has basically all 460 parts, it's cammed, NOT THE ORIGINAL ENGINE. Originaly had a 360 in it. The radiator was brittle and leaking. Time for a new one. I heard they run hot? So because of this i want to know the be$t possible radiator i should get. Period.
Radiators - C&R Racing
Number4
04-21-2017 10:21 AM
67nukeford
11-28-2009 08:49 AM
