What is this and can I remove it?
Hi,
New Excursion owner. 2000 with the 7.3. Love it so far! I was wondering if someone could help me with the purpose of this rock catching piece of metal hanging down and tell me what would happen if I remove it? It is on the crossmember under the back of the transmission.
Thanks!
And there is another one above the rear driveshaft that I am not as worried about...
Thanks!
https://www.ford-trucks.com/forums/1...l#post12733596
From some of the other threads Scott linked to in his post. Let the fun begin...again:
Can you tell we answer this question all the time?
Stewart
https://www.ford-trucks.com/forums/4...his-thing.html
https://www.ford-trucks.com/forums/5...the-frame.html
https://www.ford-trucks.com/forums/5...-attached.html
https://www.ford-trucks.com/forums/9...excursion.html
https://www.ford-trucks.com/forums/1...king-down.html
https://www.ford-trucks.com/forums/1...-removing.html
Look at it carefully. It increases the drag coefficient of the truck. That makes it use more fuel. Big oil doesn't want you to cut back on fuel usage so they bribed Ford to put it in. Also, when the CIA or FBI wants to track you, they will remove it and install one of their own that looks like yours but has a transmitter to pinpoint your position, record your conversations and figure out your underwear size if you wear underwear or if you are cleanly shaven "down there".
Stewart
No worries meaning there is almost no way to search on the forum for "odd metal cube under truck bolted in place" and get a result Leave it alone. There's a company (TritonPower.com) that makes a carbon fiber one though so you can drop 7 pounds of weight off the truck and still have the vibration dampening. It's like $350 but I love mine! Woke my 5.4 up and I eat 6.0's for breakfast now.
Stewart
