Truck sometimes not responding to throttle,yesterday was backing into drive, gave full throttle and stayed at idle. Also had P0299 code. I do have the scangauge but not sure how to tell which is causing my issue. Could this be the sensor on pedal or the turbo stuck?
You can test the ICP sensor by unplugging it and seeing if it will start and have pedal. You should also monitor the volts from the ICP sensor (ICV). I would also watch ICP, IPR, FMP at the same time.
Then if not that you can monitor VGT to start your check on the turbo.
Yes you can drive it, but I wouldn't go far because the readings you are getting with it unplugged are fake from the computer. You can get the sensor on eBay for $40
Ok White Bear has a decent price, just trying to make sure before I buy that it will fix my problem, don't want to buy parts without knowing for certain as they are non returnable.
I would still like to know why my throttle sensor inputs are not reading.
You can drive as long as you like with the sensor unplugged to verify.
As for Scangauge, those are User generated codes and there are several X-Gauges for Scanguage that do not work properly.
