1952 215 aluminum two one barrels linkage
Welcome to FTE!
To use that successfully, you need to get a different type of distributor, as the trucks came with what is known as a Load-A-Matic from the factory. That used a special carburetor that produced a vacuum advance signal that (supposedly) allowed Ford to get rid of a mechanical advance mechanism. With two carbs, the signal is all wrong, so there are various ways to get the stock distributor modified or replaced to get a proper advance curve.
This is where most people get their distributors modified: Bubba's Hot Rod Shop - 1330 Main St., Speedway, IN 46224
Thanks to Stu for saving me the time posting the pictures. I had nothing but trouble getting both carbs dialed in. Hopefully Ross is correct about the distributor. I didn't go that far and just went back to the stock set up.
The Offenhauser 2x1 intake is available in reproduction. The linkage is included with the purchase. You may want to contact Offenhauser to see if they'll sell the linkage separately.
No. Just to be clear, you can "run" the stock distributor but it will not give much advance, will run poorly. You need one with mechanical advance and vacuum advance, see the link in Post #3. (Note that Bubba is moving his shop and taking a vacation until after the new year)
Bubbas orders for january 2015 - The Ford Barn
scottddove
11-26-2007 05:27 PM
