door ajar and interior lights won't go off
on
Try spraying wd40 or some other type of lubricant into the bottom of your door latches and open and close your door a few times it should loosen the switch. Its a common problem with mine I had to replace my driverside switch as it was beyond repair. If that doesn't work you will have to pull your fuse until you get it repaired.
Received 3,678 Likes
on
