"Tech: I built my AC hoses with E-Z Clip System
drptop70ss,
I was just not happy with a bunch of plastic sticking out from under the dash so I went with the New Mark IV with metal and chrome plus I didn't want to cobble the glove box up.
I made small 2 flat plates that bolt to the bottom of the dash to extend toward the firewall about 2" long and used the supplied angle brackets to bolt to them on each side. Watch out for the location of the left glove box bolt. At first I covered that hole up and had to re-do. I don't remember if I used that bolt to attach the flat bracket or not. The back strap brace just bolted to the firewall.
I will check tonight and see if I can get a picture. I bought a couple of foot of chrome fender welt to go between the unit and the bottom of the dash.
Building AC hose with the E-Z Clip
I have ample room to grab the vent handle like a bat and work it. I mounted the unit as close to the glove box hinge as possible. If you look at the front view of the unit you can see the vent handle on the left of the unit.
I had a Boo Boo before I tried to charge the unit as I drilled into one hose behind the firewall when mounting an electrical harness clamp and had to make a new hose.
I seem to have a small leak when I try to pump it down so I will run a dye test Monday to see what I can find. Guess it might be the seal on the new compressor that had not seated
TractormanBill
TractormanBill
#28
#29
#30
