No power under a load
I have recently started working on our old family truck that has been sitting for a while. I rebuilt the carb a 1406 edelbrock. The truck idles great but when I put it in gear and start to drive it hesitates and stumbles horribly and has no power. When I turn it off it continues to run for a second or two. Then After it gets warmed up it also it very hard to start almost like the the distributor is out. The mechanic that put a new motor in was a family members friend but I don't think he was all that great. Anything might help thanx
To me it sounds like a lean condition. Check for vacuum leaks or collapsed fuel lines....but since you rebuilt the carb I would also go over of with a fine tooth comb.
Timing and dwell if you have a points type ignition is also a quick easy check that should be verified before getting to deep in to anything else.
05-27-2014 12:14 PM
rdvs
01-28-2010 03:53 PM
ramarado
06-21-2008 08:58 AM
Mav06
33
03-01-2007 11:07 AM
stevef100s
04-08-2004 10:09 PM
