Ford truck information and then some....
#136
meangreen92 with some words of wisdom that I had to save for others to see. This covers an issue of blowing a fuse in the fuse block (top R/H #2 in the diagram) when you connect an aftermarket radio to the OEM connection improperly. And BTW the OEM connection is the green square plug.
"Improper radio installation, the common mistake is to use the blue-with-red-stripe wire as a ground, since it shares a connector with the yellow switched-12V+ wire, and that will blow that fuse the first time you turn on the lights and hit the brake. That blue-with-red-stripe wire is for the dial light in the original factory radio, so if it gets grounded, it will pop that fuse."
https://www.ford-trucks.com/forums/1...l#post17791311
#137
#138
#139
None PDF version. And where to get the bushings/insulator. Thanks ND.
1) C6TZ-6A061-A .. T/C Insulator / Obsolete/Reproduced?
NOS PARTS LTD in Waxahachie TX has 3 = 972-937-2201.
1) C6TZ-6068-D .. T/C Insulator / Obsolete/Reproduced?
GREEN SALES CO. in Cincinnati OH has 4 = 800-543-4959
CARPENTER NOS OBSOLETE PARTS in Concord NC has 10 = 800-476-9653.
NOS PARTS LTD has 11.
#140
FYI: 1973/79 Ford Light Truck Parts Catalog available on a C/D from hipoparts.com
Did you buy a parts CD and need help figuring out part #'s ? https://www.ford-trucks.com/forums/1...-number-s.html
Thanks mikeo0o0o0
Thanks mikeo0o0o0
#141
#142
#143
The following users liked this post:
#144
I just read thru this thread and realized this guy is really onto something and wanted to pass it along.
https://www.ford-trucks.com/forums/1...w-starter.html
Take you time and really READ it and understand what he is explaining here. DO NOT be under the gun to get your truck fixed in 2 min.
#145
#146
#147
#148
#149
To put some shoulder belts in your truck you can get some belts and reels and mount them like in a 77-79 reg cab. Cutting the large hole in the cab wall to mount the reel. Or just mount the SC set up and only have to mount the 2nd shoulder point to the cab wall and put the reel on the floor.
https://www.morris4x4center.com/fron...ach-belt3.html
#150
