The mother of invention.......
Old 09-25-2014, 10:17 PM
bra$$monkey's Avatar
bra$$monkey
bra$$monkey is offline
Check this out. I installed a barrel tank in the bed of my truck. I made the mistake of sealing up the sending unit with huge gobs of silicone. It sealed up nice - but.....huge gobs of silicone get sucked into the fuel line & kill the truck!
I've been stranded 3 times now - even after I thought I'd cleaned out the junk.
I needed another plan.
I picked up a brass nipple & had a brake line on the shelf. I stuffed the brake line into the nipple & soldered it in.
Then I cleaned it up some
& cut off the excess brake line
Then I attached a screen to the end - this way any remaining gunk in the tank can't get sucked into the end of the line.
I used aluminum tape - It took a couple of tries to find something that would work - I used a fare tool to spread out the end of the tube to give something to grip - once that was there the screen attached really tight.
The truck fired right up - I know its not perfect - but I bet I don't get stranded by silicone boogers any time soon!
Old 09-26-2014, 02:55 AM
fordman75's Avatar
fordman75
fordman75 is offline
The problem I see now is you'll have to worry about that tape plugging stuff up instead of silicone.
Old 09-26-2014, 04:20 AM
Byooty's Avatar
Byooty
Byooty is offline
I must of slept in, didnt know it was April Fools day?
You must be kidding with that "fix" right? bodgy solder job and duct tape........
Old 09-26-2014, 11:47 AM
bra$$monkey
Yup - its my redneck fix.
Believe it or not it works really well & the only down side would be the same issue i started with. Whats to lose?
Haters be damned! I like my fix!
Old 09-26-2014, 11:55 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Does it stick in horizontally or vertically? If vertical, it would seem to leave a lot of gas in the tank when you "run out of gas".
Old 09-26-2014, 11:56 AM
Malakilla's Avatar
Malakilla
Malakilla is offline
The solder does not bother me.... just the tape. Hell a piece of stainless wire twisted tight would give you a better solution. If I was on the side of the road....I would have skipped the screen and said you did great.
A much better filter would be an in line type. That way you can service it and replace as needed.
Old 09-26-2014, 12:01 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Filter won't do anything if no gas can get out of the tank. The tank is full of silicone blobs. They should be cleaned out.
Usually tanks with a bottom outlet have about an inch-long standpipe so all the crap that collects can't get into the line. This appears to be almost a 6" long standpipe? Unless it's horizontal.
bra$$monkey
I didnt mention that part. I have an inline filter just oilutside the tank.
Nothing can get into my engine.
I agree the tape is cheezy. I tried a zip tie but that didn't work.
I soaked the screen & tape in gas for 30 minutes & it didnt loosen. Maybe it will after a forever soak in gas. The aluminum screen is twisted on pretty good & with the flare at the end of the line it will stay in place. The tape was more a suspendrrs & a belt
Old 09-26-2014, 12:02 PM
bra$$monkey
6 inches is about right
Old 09-26-2014, 12:45 PM
filthy6's Avatar
filthy6
filthy6 is offline
I would like to see the barrel tank in the bed if you have a picture. Thanks
Old 09-26-2014, 12:46 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
Plugged gas lines are frustrating. Almost fixed gas lines especially so. Hope it works.
Old 09-26-2014, 12:51 PM
bra$$monkey
This fuel pick up is horizontal and about 1/2 inch off the bottom of the tank.
I have cleaned silicone boogers out 3 times. more keep appearing. Im not going to pull the sending unit as any reinstall will net me even more boogers - silicone or otherwise.
I thought it was a good fix for what it was. It got me back on the road reliably.
I like the idea of using stainless wire twisted to hold it on. next time i have an empty tank i may just pull it out & add that to the fitting.
Sorry for the confustion with my pics - they all loaded sideways for some reason.
Old 09-26-2014, 01:02 PM
bra$$monkey
Old 09-26-2014, 02:36 PM
ALBUQ F-1's Avatar
ALBUQ F-1
That tank with those supports would make me very nervous. Are you planning a new tank under the bed, or?
Old 09-26-2014, 03:01 PM
bra$$monkey
More nervous than the tank sitting behind the drivers seat inside the cab?
This tank is made from thick steel - much more sturdy than the one it replaced - & if there is an accident God forbid, its not sitting inside with me.
No - I do not plan to put a tank under the bed - I have a reese hitch back there - I had investigated the under bed tank before going this direction.
Quick Reply: The mother of invention.......
