Will home audio RCA's work instead of car audio ones?
Heres a secret, it's all the same cable. 75ohm coaxial cable. In fact the stuff you use for cable TV is the same as that stuff, just a different connector.
Sure there will be differences in sheilding and that, but fundamentally it's all basically the same stuff. So to answer your question, yes the home audio stuff will work.
keep it away from the power wires or your stereo will sound crapy at low volume.example put power wires on driver side going to the amp and rca on passeger side going to the amp. this way you charging system will not effect the sound quilty.
BIGDZL
6.7L Power Stroke Diesel
17
04-11-2018 11:29 AM
GNR22
05-28-2015 04:06 PM
mercurymusic
04-28-2015 07:48 PM
osricmason
1999 to 2016 Super Duty
06-19-2014 01:58 PM
sle77
04-18-2004 05:05 PM
