6.9 deisel questions
i may be picking up a 1985 f250 with a 6.9 new to the old deisel game truck has 300K on it but just had a new injector pump put on not two days ago any major mechanical issues with these engines truck is 2 wheel drive with a 4 speed trans mission any help would be apriciated
The 6.9 is a rock solid motor. Properly cared for, they will serve well for well over 300k. They are not speed demons but they'll pull down a mountain. If they have a weak point, it's probably head gaskets. The head bolts are smaller in size (7/16" IIRC) and don't clamp as well as the 1/2" bolts. If the engined is non-turboed, that really shouldn't be an issue. There is a lot of good, diesel specific info on Oilburners.net and www.thedieselstop.com
i just bought a 1986 ford e350 van 6.0 diesel its been siting for 5 years the glow plugs will not come on . when i turn the key i have no glow plug light . when cold will only start with starting fluid is there a fuse or system just needs cleaned for siting so long . run great when started and once hot starts right up first diesel i ever had . i will need to learn a lot about diesel engines i am mechanicly inclined worked on many gas engines but not diesels the van has 36,000 miles
The newer system looks like this.
steve5588
06-29-2009 01:10 PM
Boficus
22
12-01-2003 02:47 PM
