NP 205... Or, not...?
on
So my 79 Bronco Is supposed to have an NP 205 TC right? Recently, looking into other resto/rebuilds I notice the other t cases don't look quite like mine but they are confirmed to be 205s. After more research I cant find any NP 205s that look like mine. So my question is what DO I have then? Ill post pics in a couple hours but for now I have some numbers off a tag on the side that read: "D9TA 7A195 NA" then a line below: "03 06 79 1 203" I can make guesses to what these numbers are but don't know much about this stuff. Any help would be appreciated. Thanks.
(I think you even got a sticker for your transfer case shifter **** with the conversion kit.) I think Mile Marker made the conversion kit.
on
Okay. So I actually did some research and found what you just said. I guess I was just confused because, well, I have a shift lever AND a 203. So the PO either converted the original 203 to part time or swapped in an originally part time 203? I also never had the **** so I don't even know the pattern. Now though, my only concern is that I haven't driven anywhere in 4 or with the hubs locked and I read that that is the only way to lubricate a 203. Thanks for the help guys.
Edit: So for some reason I was under the impression that if the 203 was full time, than it wouldn't have a shift lever. Obviously I didn't consider high and low range. I assumed that the presence of the shift lever meant the 203 was converted. Guess not. Okay, so I do have manual hubs but there is still a possibility that the 203 isn't converted and I've just been driving around in 4h or 4h loc but the hubs have been free. The easiest way I can think of determining if I do have a converted 203 is jacking up the rear end, unlocking the front hubs, shifting through the t case gears and seeing if anything turns the rear but doesn't turn the front driveline. Any easier ideas? Am I still missing something?
on
Thought of that but its just me and myself. However, I drove down the road with it in every position and one position (second to last back and what I've been driving around with previously) I couldn't hear the front driveshaft turning anymore so i'm assuming this IS IN FACT 2h. Is it a problem that I can hear the gears/driveline in all other positions (4x4)?
EDIT: wrote that last one before I saw your post torky. Good idea though.
on
So reviving an old thread because I need a new spedo cable. Turns out I do have a converted 203. LMC sells the cable for 20 bucks but there are 3 different options. "part time 4x4", "full time 4x4" and "lower cable"? I assume i should order the full time 4x4 spedo cable even though mine isnt full time anymore, but i am not sure. I still dont know what kit was used in the conversion but I wonder if anyone knows which cable i should buy?
76hi-boy
01-05-2005 03:35 PM
Caldwell F150
04-23-2004 10:59 AM
