6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
What Did You Do To Your 6.4L Today?
  #271
Old 03-31-2016, 07:57 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
Originally Posted by Chainsaw233
My turbo is maxing out PSI and no power. Makes a rumble/grinding noise when slowing down rpms. sounds like the impeller is rubbing to me, but I don't know. I just replaced the transmission and now this starts a week later. Any advice, or am I now due to rebuild the turbo? she has 185k on her. 2008.
side note, I filled up the other day and noticed it was biodeisel after pumping a tank full in. Getting codes of Turbo Performance and Emissions Test not complete.
I would check for exhaust leaks. Can you monitor EGT's and Exhaust Back Pressure? If so, keep an eye on those and get back to us.
  #272
Old 04-01-2016, 06:43 PM
CrazySob's Avatar
CrazySob
CrazySob is offline
Finally found some free time to start getting rid of some of the damn chrome on my truck. Still can't for the life of me understand why the previous owner put this crap on it. I have had it for almost 3 years and just couldn't stand it anymore.
Also got an updated set of tuning (shout out to Jeremy and Mike at NoLimit Fab) from Gearhead. Finally have a tow tune that I actually enjoy driving and the sound change/turbo whistle with the veins commanded open at idle sounds epic. Now just waiting on a set of Fox 2.0s and I can get to work on tires and leveling kit as well.
  #273
Old 04-01-2016, 07:44 PM
ginomachino's Avatar
ginomachino
ginomachino is offline
replaced the two fan belt idler pulleys and the tensioner today. scratched up my forearms pretty good, but very easy otherwise. I couldn't believe the difference in the tensioner spring difference between the old and the new one. Quieted the engine noise tremendously.
  #274
Old 05-29-2016, 06:18 PM
ginomachino
today I replaced my rusted out rear brake dust shields, replaced the parking brake shoes and all the hardware, did a tire rotation and took it for a spin. no more brake squeal and no steering shake for a while. Next I will be replacing all three tie rod ends and the drag link.
i still have to replace the fluids in the trans and transfer case, and both differentials.
  #275
Old 05-30-2016, 09:52 AM
JcF204's Avatar
JcF204
JcF204 is offline
Front leveling kit, front brakes, new batteries and belts. Timbren springs. Ready for summer!
  #276
Old 05-30-2016, 03:37 PM
fatboytx's Avatar
fatboytx
fatboytx is offline
Which leveling kit did you use? Where you happy with it? Ease of install? Did it move your alignment much? How much lift in the front?
  #277
Old 05-30-2016, 04:12 PM
JcF204's Avatar
JcF204
JcF204 is offline
I used Motofab from ebay. 2" leveling kit. I didn't think the alignment changed much but I had it done anyway.
Like most things, I could do the install in half the time if I did it again! But it wasn't too bad, did it in my driveway. The trick was getting the suspension low enough to install the springs with the spacer, taking it out was pretty easy. Hard to jack up such a big truck high enough.
So far I am happy with it. Good luck!
  #278
Old 06-08-2016, 04:05 PM
slowmans's Avatar
slowmans
slowmans is offline
Drained and refilled the front Diff with Amsoil 75w90 and drained and refilled tranny with 5.5 quarts of LV. 46k on the ticker.......
  #279
Old 07-03-2016, 06:46 PM
73fan's Avatar
73fan
73fan is offline
I haven't been back here for a long time... it's been two weeks ago since I sold mine. Well really the selling took place two months earlier, but two weeks ago the new owner came and picked it up. It was a great truck and letting it go was a long process...but I had to.
It got every ding and dent fixed and the color changed to Caribou Metallic. Then it went to its new home not far from Seattle, WA.
  #280
Old 07-03-2016, 07:06 PM
73fan's Avatar
73fan
73fan is offline
Delete double post.
  #281
Old 07-03-2016, 09:21 PM
jimh425's Avatar
jimh425
jimh425 is offline
Emptied the water separator, added a fumoto valve, and changed the oil.
  #282
Old 07-14-2016, 08:23 AM
ginomachino
Was cruising the craigslist and found Rancho RS5000 series shocks that were only used for a couple of weeks. Went to check them out and they looked brand new. Got them for 80, put them in and so far I noticed a big difference in how the suspension responds. My truck had the original shocks in the rear and Blistein 5100 in the front. The truck has always felt out of balance front to rear. I am liking the Ranchos so far, although the truck does feel a little like an 85 Cadillac lol. I think my next step will be adjustable damping shocks so i can make the suspension a little stiffer for when i tow
  #283
Old 03-19-2019, 01:32 PM
73fan's Avatar
73fan
73fan is offline
This thread seems to have fallen by the wayside! I don’t do much with my 6.4L anymore. As you’ll see several posts back, I sold mine. But I had to come back. A few months later I purchased another 2008 6.4L that came with worn rockers. I did them and also went with stage 2 billet camshaft from Colt Cams. Anyway, my truck stands in the front yard because it looks good. Otherwise, I drive the car for commuting.
  #284
Old 03-19-2019, 01:50 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is online now
traded my 6.4 last week.
but here is a catch up on what I did to my 6.4 today
450 intake cooler
150 coolant filter
250 oil by pass filter
700 air dog
400 shocks
125 front hitch
150 overleaf
600 Evans coolant
250 screen oil filter
400 trans pan
500 hubs
800 rockers
250 code reader
400 preluber
400 4 draw storage
800 diamond truck back
400 sulastic springs
2400 fox 2.5 shocks
600 sumo springs
400 dual oil filter
400 Centronics balacer
400 Dual steering stabilizer
400 spare tire
1000 3 alloy rims
1400 hood and paint
200 Front lift
350 Rear lift
1400 Traction bar
  #285
Old 03-20-2019, 04:56 AM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
Good to see you back, brought another 6.4 back to life!
Quick Reply: What Did You Do To Your 6.4L Today?
