What Did You Do To Your 6.4L Today?
#196
#197
#200
#201
Well I hate to say it but what I did to mine....I put it up for sale. Things seem to be running me into a bind and the truck is one thing I may be able to get some money for ...
View it here:
08 KING RANCH,
http://www.kijiji.ca/v-cars-trucks/e...nch/1089438532
View it here:
08 KING RANCH,
#202
#204
Nope, no luck so far...
So I did a little more work to it. On Saturday the CD player just plain quit. It would take a disc in but then say bad disc and wouldn't eject it unless I selected load disc and chose the slot that had the disc in, then insert the disc and it would spit both out.
So today I took the stereo out, opened it up and found one little arm was bent that holds the disc in place. So I bent it back and blew it out with compressed air and what do you know?! My 6CD mp3 player works again!
I then also found why the auxiliary input only played through one side. One of wires was just plain cut. About 6cm from where it enters the rear of the stereo...so I soldered it together and now it all works better than it did when I bought the truck!!
#205
#207
#208
#209
I picked up a used Max Energy tuner by Hypertech off Craigslist. It was only $100 so I figured it is worth a try. All the reviews I could find were mostly very good.
I still have a warranty so I cannot delete the DPF. I installed it and put it on Stage II. You can certainly feel the improved power and the trans seems to shift smoother. I have no illusions this will improve MPG. But I did notice the throttle response seems much improved. My truck typically has a almost a slight hesitation when stomping on it, not anymore!
