What Did You Do To Your 6.4L Today?
#181
Put a couple "Power Stroke Diesel" decals on.
https://drive.google.com/file/d/0B1e...p=docslist_api
What do you think?
What do you think?
#182
Did a coolant flush,switched to CAT ELC and changed T-stats, started it Friday night by draining coolant and then finished it yesterday morning. I used 1 gallon of restore + and about 25 gallons of distilled water, after the water was coming out clean I changed both thermostats and buttoned it all back up and refilled with then ELC. I wasn't having any issues prior and my temps (deltas) have always been good but with the truck being 5 years old I wanted to get the gold out!! Currently have just over 43,000 miles on her and she's running great!
#185
6.0 exhaust manifolds
Just recently put 6.0 exhaust maniflods with new up pipes. ( belw the belows of the old up pipe 800 miles into a 3600 mile trip.) What a pain mod to do with out a lift or crane to remove the body. Huge gains in lowering the EGT's. I would guess it lowered them about 150 degrees pulling my 18,000lb trailer over a steep grade and was able to maintain a high rate of speed. (45mph was producing 1350 deg, 55-60 mph 1150-1200 deg.)
#186
#187
#188
Flow
The runners are longer and the exit is radius-ed better. You have the do the up pipes and manifolds together. Besides being tight going in, you have to redesign the heat sheild on the passenger side at the A/C compressor. Since I had to raise the cab to replce the blown drivers up pipe, I decided to do it all. I was already EGR deleted.
#189
#190
#193
#195
