What Did You Do To Your 6.4L Today?
#271
My turbo is maxing out PSI and no power. Makes a rumble/grinding noise when slowing down rpms. sounds like the impeller is rubbing to me, but I don't know. I just replaced the transmission and now this starts a week later. Any advice, or am I now due to rebuild the turbo? she has 185k on her. 2008.
side note, I filled up the other day and noticed it was biodeisel after pumping a tank full in. Getting codes of Turbo Performance and Emissions Test not complete.
#272
Finally found some free time to start getting rid of some of the damn chrome on my truck. Still can't for the life of me understand why the previous owner put this crap on it. I have had it for almost 3 years and just couldn't stand it anymore.
Also got an updated set of tuning (shout out to Jeremy and Mike at NoLimit Fab) from Gearhead. Finally have a tow tune that I actually enjoy driving and the sound change/turbo whistle with the veins commanded open at idle sounds epic. Now just waiting on a set of Fox 2.0s and I can get to work on tires and leveling kit as well.
#273
#274
today I replaced my rusted out rear brake dust shields, replaced the parking brake shoes and all the hardware, did a tire rotation and took it for a spin. no more brake squeal and no steering shake for a while. Next I will be replacing all three tie rod ends and the drag link.
i still have to replace the fluids in the trans and transfer case, and both differentials.
#276
#277
Like most things, I could do the install in half the time if I did it again! But it wasn't too bad, did it in my driveway. The trick was getting the suspension low enough to install the springs with the spacer, taking it out was pretty easy. Hard to jack up such a big truck high enough.
So far I am happy with it. Good luck!
#279
I haven't been back here for a long time... it's been two weeks ago since I sold mine. Well really the selling took place two months earlier, but two weeks ago the new owner came and picked it up. It was a great truck and letting it go was a long process...but I had to.
It got every ding and dent fixed and the color changed to Caribou Metallic. Then it went to its new home not far from Seattle, WA.
#282
Was cruising the craigslist and found Rancho RS5000 series shocks that were only used for a couple of weeks. Went to check them out and they looked brand new. Got them for 80, put them in and so far I noticed a big difference in how the suspension responds. My truck had the original shocks in the rear and Blistein 5100 in the front. The truck has always felt out of balance front to rear. I am liking the Ranchos so far, although the truck does feel a little like an 85 Cadillac lol. I think my next step will be adjustable damping shocks so i can make the suspension a little stiffer for when i tow
#283
This thread seems to have fallen by the wayside! I don’t do much with my 6.4L anymore. As you’ll see several posts back, I sold mine. But I had to come back. A few months later I purchased another 2008 6.4L that came with worn rockers. I did them and also went with stage 2 billet camshaft from Colt Cams. Anyway, my truck stands in the front yard because it looks good. Otherwise, I drive the car for commuting.
#284
traded my 6.4 last week.
but here is a catch up on what I did to my 6.4 today
450 intake cooler
150 coolant filter
250 oil by pass filter
700 air dog
400 shocks
125 front hitch
150 overleaf
600 Evans coolant
250 screen oil filter
400 trans pan
500 hubs
800 rockers
250 code reader
400 preluber
400 4 draw storage
800 diamond truck back
400 sulastic springs
2400 fox 2.5 shocks
600 sumo springs
400 dual oil filter
400 Centronics balacer
400 Dual steering stabilizer
400 spare tire
1000 3 alloy rims
1400 hood and paint
200 Front lift
350 Rear lift
1400 Traction bar
450 intake cooler
150 coolant filter
700 air dog
400 shocks
125 front hitch
150 overleaf
600 Evans coolant
400 trans pan
500 hubs
800 rockers
250 code reader
400 preluber
400 4 draw storage
2400 fox 2.5 shocks
600 sumo springs
400 dual oil filter
400 spare tire
1000 3 alloy rims
1400 hood and paint
200 Front lift
350 Rear lift
1400 Traction bar
#285
