6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
What Did You Do To Your 6.4L Today?
Old 06-26-2015, 08:32 PM
73fan's Avatar
73fan
73fan is offline
Put a couple "Power Stroke Diesel" decals on.
https://drive.google.com/file/d/0B1e...p=docslist_api
What do you think?
  #182
Old 07-05-2015, 01:04 PM
slowmans's Avatar
slowmans
slowmans is offline
Did a coolant flush,switched to CAT ELC and changed T-stats, started it Friday night by draining coolant and then finished it yesterday morning. I used 1 gallon of restore + and about 25 gallons of distilled water, after the water was coming out clean I changed both thermostats and buttoned it all back up and refilled with then ELC. I wasn't having any issues prior and my temps (deltas) have always been good but with the truck being 5 years old I wanted to get the gold out!! Currently have just over 43,000 miles on her and she's running great!
  #183
Old 07-07-2015, 11:08 AM
73fan's Avatar
73fan
73fan is offline
Hey there slowman, do you have a coolant filter on yours?
  #184
Old 07-07-2015, 01:13 PM
slowmans's Avatar
slowmans
slowmans is offline
Yes, i do. Its been on since about 4300 miles and never really has any debris.
  #185
Old 07-07-2015, 03:32 PM
speedyfz1's Avatar
speedyfz1
speedyfz1 is offline
6.0 exhaust manifolds
Just recently put 6.0 exhaust maniflods with new up pipes. ( belw the belows of the old up pipe 800 miles into a 3600 mile trip.) What a pain mod to do with out a lift or crane to remove the body. Huge gains in lowering the EGT's. I would guess it lowered them about 150 degrees pulling my 18,000lb trailer over a steep grade and was able to maintain a high rate of speed. (45mph was producing 1350 deg, 55-60 mph 1150-1200 deg.)
  #186
Old 07-07-2015, 11:54 PM
73fan's Avatar
73fan
73fan is offline
I've been thinking about putting one on mine... Did you buy a complete kit or did you buy a filter and base and set it up on your own?
  #187
Old 07-08-2015, 09:09 AM
73fan's Avatar
73fan
73fan is offline
Wow I don't know that I ever heard of doing that before. Are the manifolds from the 6.0L that much bigger or simply more flow friendly by design?
  #188
Old 07-08-2015, 09:37 AM
speedyfz1's Avatar
speedyfz1
Flow
The runners are longer and the exit is radius-ed better. You have the do the up pipes and manifolds together. Besides being tight going in, you have to redesign the heat sheild on the passenger side at the A/C compressor. Since I had to raise the cab to replce the blown drivers up pipe, I decided to do it all. I was already EGR deleted.
  #189
Old 07-08-2015, 11:25 PM
slowmans's Avatar
slowmans
slowmans is offline
I bought the Dieselsite kit, works as described.
  #190
Old 07-10-2015, 12:46 AM
73fan's Avatar
73fan
73fan is offline
Well I fed my truck another 82L of fuel. Then drove it about 70 km. That's about all I do to it nowadays. Put in fuel, then burn it and turn some kilometers on... Hmm, I should drain the water separator again.
  #191
Old 07-10-2015, 01:31 PM
73fan's Avatar
73fan
73fan is offline
Got that done. Didn't appear to be any water in it so that's a good thing.
  #192
Old 07-14-2015, 12:18 AM
73fan's Avatar
73fan
73fan is offline
Well I can't seem to post a photo here, but today I rolled the odometer over the 350,000 KM!
  #193
Old 07-14-2015, 04:17 PM
slowmans's Avatar
slowmans
slowmans is offline
Whats that in miles? What major work has been done again, I know I have seen it somewhere...
  #194
Old 07-14-2015, 04:39 PM
dlibson's Avatar
dlibson
dlibson is offline
217,000 roughly...
  #195
Old 07-14-2015, 04:48 PM
73fan's Avatar
73fan
73fan is offline
Yes, that's 217,000 miles.
It's at the beginning of this thread where I changed the camshaft and lifters. Also added the H&S Mini Maxx at the same time. That was in October of 2014.
Truck had 334,303 km (207,XXX miles) at that time.
Quick Reply: What Did You Do To Your 6.4L Today?
