losing hope! please help my sick 88 F150!
Hi
I have been trying to fix my truck with no luck, problem is that when is idling the rpm's would go crazy to the point that it seems the motor would stall and when i drive it feels rough.
My truck is an 88 f150 4.9 L6, 4 speeds and i have replaced the following:
EGR
PCV
IACV
TPS
INTAKE GASKET
MAP SENSOR And i even replaced the ECU with a same number ecu i found on ebay, So o don't know what else to do. The only thing i haven't tried is replacing the throttle body gasket.
Please help.
I am posting a link to a video i uploaded so you guys could see the problem.
F150 4.9 L6 crazy rpm's:
EGR
PCV
IACV
TPS
INTAKE GASKET
Please help.
Fuel filter was replaced probably at around 10,000 miles ago.
Your TPS is still screwed up in my opinion....Test it or replace it again. Part 1 -Throttle Position Sensor (TPS) Test (Ford 5.0L, 5.8L)
Spray some carb cleaner around your throttle body gasket as its running see if your getting leak. Engine should rev up higher.
Update 4.9L: http://troubleshootmyvehicle.com/for...test-the-tps-1
Update 4.9L: Part 1 -How to Test: Throttle Position Sensor (1988-1995 Ford 4.9L)
Illbethejudge
09-08-2014 01:36 PM
DrFord
03-28-2008 01:15 PM
KAS300
08-28-2006 11:13 PM
Emt_Fireman
08-11-2002 04:42 AM
