Question for People with Grill guards on their 87-91s
Old 09-24-2014, 04:12 PM
FordTruckfan89's Avatar
FordTruckfan89
FordTruckfan89 is offline
I recently purchased a chrome 87-91 Westin Grill Guard. Little did I know it was missing some bottom brackets that clamp to the bumper. I'm asking the PO if they by chance have them, but otherwise I will make some. I was wondering if those with similar grill guards or the same guard could post a picture of the lower bumper brackets? attached a pic of the guard.
Old 09-24-2014, 05:20 PM
SteelHorse4x4's Avatar
SteelHorse4x4
SteelHorse4x4 is offline
My dad has one he took off his 89. Problem is he's in TX right now and guard and truck are in WI. I'll update but it could be a while.
Old 09-24-2014, 05:50 PM
tezm's Avatar
tezm
tezm is offline
I had one on a donor truck so just took a look, unfortunately there were no lower brackets, a hole had been drilled and a bolt inserted. The bottoms of mine do have a flange though, so a simple 'J' shaped bracket could be made to work.
Old 09-24-2014, 06:23 PM
FordTruckfan89
the top brackets clip around the bumper edge and then bolt to the guard. so the bottom would probably be similar. Thank you. And SteelHorse4x4,don't worry about it, thanks though.
Old 09-24-2014, 06:55 PM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
Understand that bolting that to your bumper does not make for a strong grille guard. The bumper isn't tough, and putting a long lever like that on it makes it extra weak.
If you hit something, like we here in WI hit whitetail deer, on one side of the truck, its going to wipe out the other side too when the grille guard folds into it.
Old 09-24-2014, 07:10 PM
FordTruckfan89
I understand that completely. One reason I got the guard is to mount driving lights on so I can see further and clearer to reduce the chance of that happening. Deer aren't bad where I'm at, but I've focused more on improving visibility, already added a headlight relay harness and better bulbs. If I end up hitting a deer, its gonna do a good bit a damage anyway you look at it, unless theres a heavy front bumper or grill guard bolted to the frame. just looking for a way to mount lights.
Old 09-24-2014, 07:16 PM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
Where are you mounting lights onto that? Are you going to cut the center bars out?
Old 09-24-2014, 07:37 PM
FordTruckfan89
I'll have to see, the bigger bars are 1.5" and the smaller ones are 1", conduit hangers or split ring hangers will work as cheap light mounts. I have fogs below the bumper that work good, just want something to add to the headlights.
conduit hanger B-LINE by Eaton Conduit Clamp,Screw On,1 In,Steel - Conduit and Cable Hangers - 4RHZ5|BL1420 - Grainger Industrial Supply
split ring hanger
GRAINGER APPROVED VENDOR Split Ring Hanger,1 In,Malleable Iron - Pipe Hangers and Clamps - 22FP59|22FP59 - Grainger Industrial Supply
much cheaper than $20 light bar clamps off amazon.
Old 10-06-2014, 11:30 PM
FordTruckfan89
UPDATE
made the brackets from 2" x 1/8" steel strap. used grade 8 1/2" fine thread zinc plated bolts. Just doing this as a reference pic if one finds themselves in a similar predicament.
driverside bracket. hangs lower than other bracket.
pass side bracket
Old 10-07-2014, 03:06 AM
Truck Guy99's Avatar
Truck Guy99
Truck Guy99 is offline
This should be stickied
Old 10-08-2014, 05:29 AM
dixie460's Avatar
dixie460
dixie460 is offline
Why? All he did was make 2 simple brackets.
OP, that's a nice looking truck!
Old 10-16-2014, 12:18 AM
FordTruckfan89
Thanks, yours is nice too.
Old 10-16-2014, 03:17 AM
krooser's Avatar
krooser
krooser is offline
Good job...
fordhamr
1999 to 2016 Super Duty
12-10-2014 02:50 PM
quinletc
10-10-2014 08:53 AM
biglee
1947 and Older Ford Trucks
02-05-2008 09:16 AM
jplyon
05-28-2006 07:41 PM
Quick Reply: Question for People with Grill guards on their 87-91s
