7.3 idi e4od to manuel 4speed
Old 09-24-2014, 02:33 PM
yanzorz71's Avatar
yanzorz71
yanzorz71 is offline
I have a 94 f250 4x4 7.3 idi whit a e4od ..
My friend a 4 speed manual tranny from a 460 i juste wanna know if it fit or can make it fit ty
Old 09-24-2014, 04:21 PM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
It's possible, you'd need a bell housing from an IDI. And I believe the gear spread on the gasser T19s are different, but I don't know if that would affect drive-ability or not.
Of course you'd be loosing the OD, the better option, if it's an option for you, would be to find a 5 speed. But if it's just a gotta make it work situation it wouldn't be hard to do what you're asking as long as you have the proper bell.
Old 09-24-2014, 10:35 PM
fordtruckman838's Avatar
fordtruckman838
fordtruckman838 is offline
Yep! the gear ratio for first is different but that is the only difference. A gasser has a lower 1st gear (around 6:1 ratio) while the diesel has a higher first gear (around a 4:1 ratio) the gasser trans is still very usable in a diesel but it is nice to be able to use the closer ratio to take off from a stop.
Old 09-25-2014, 11:04 AM
ZombiePopper's Avatar
ZombiePopper
ZombiePopper is offline
My truck is a man trans t19, or t18? Anyway it's a great trans and I wouldn't swap it for any auto trans, (except maybe a 5spd man trans ZF) but what gearing is in your axles?
Are you running larger tires?
These ^ are going to make a big difference with that 4spd's shift points, and how much shifting in town you're going to have to do plus your highway speeds/rpm's,
Just something to consider..
Old 09-25-2014, 11:56 AM
fordtruckman838
If it has a synchro on first it is a T-19 that is the easiest way to tell.
Old 09-25-2014, 12:24 PM
madpogue's Avatar
madpogue
madpogue is offline
1987 truck would have a T-19B (B meaning close-ratio).
I always thought a T-18 or T-19A - wide ratio tranny - with the 3.07 (or is it 3.06?) gearing would be a cool combination. Only four gears to shift through, but a final drive comparable to an overdrive with 3.55s.
To the OP - is your truck a 4x4? Is the donor truck a 4x4?
Old 09-25-2014, 12:40 PM
Red454sedgwick's Avatar
Red454sedgwick
Red454sedgwick is offline
you'll also have to change the drive shafts and trans cross member, what is wrong with the e4od.
Old 09-25-2014, 03:24 PM
yanzorz71's Avatar
yanzorz71
I know about cross membre driveshaft and aller that i got m'y new tranny whit the good bellhousing nos my last question .. Is clutch/flywheel from 460 will fit on m'y 7.3 .....
Nothing rong whit m'y e4od just dont like auto .. Its for sell if some 1 want it make an offer
Old 09-25-2014, 04:42 PM
fordtruckman838
Flywheel: No, they are balanced differently,(and possibly different bolt pattern) you need a flywheel for the IDI and specifically since yours is a 94 (assuming your motor is a 93 or 94) it has to be for an 93 or 94 IDIT. The good for you news, is since the dual mass flywheels had issues, it is easy to get a clutch/flywheel kit.
I am not sure on the engines that had a zf5 behind them due to different input shaft size, but my 86 6.9 has the same bolt pattern and spacing on the flexplate as the 85 460 I parted out.
Old 09-25-2014, 04:45 PM
fordtruckman838
Quick thought: you may have to buy the flywheel and clutch kit separately if you want to use the t-19 as it has a different input shaft size than the zf5 and the 93-94 clutch/flywheel kits come with the clutch disk for the zf-5
Old 09-25-2014, 04:59 PM
yanzorz71's Avatar
yanzorz71
I can get a flywheel from a 88 non turbo but dunno if it gonna fit
Old 09-25-2014, 05:38 PM
fordtruckman838
The 88 flywheel is balanced differently. It will not work.
Old 09-25-2014, 05:41 PM
yanzorz71's Avatar
yanzorz71
What you suggest then can i use clutch pressure plate from thé 460 tranny i got whit a 93-94 flywheel? Sry for aller those question lol
Old 09-25-2014, 05:54 PM
fordtruckman838
Yes, it will fit. I just compared the 460 clutch and the 6.9 clutch I have in back. they are the same.
Old 09-25-2014, 05:57 PM
yanzorz71's Avatar
yanzorz71
OK so just a flywheel for a 93-94 and im good you think
Quick Reply: 7.3 idi e4od to manuel 4speed
