clutch fork and the steering issues
Hey Guys. I'm putting a 390 (came with the T18 4 speed) into my 59 F100 . I'm stuck because the clutch fork and the steering (manual) box want to take up the same space. Id like to keep it a 4 speed (on the floor) - perhaps another manual tranny might work? Ideas to get around it .... Thanks Much!
Thanks for the responses. I'll look into the throw out bearing suggestion.
The 390 and T18 tranny came out of a 68 F100. The 59 F100 i'm putting it into was just a shell when I bought it. So I'm trying to utilize the clutch linkage from the 68 and that is where the problem is not necessarily the clutch fork.
What trans do you have in your 60?
Clutch linkage makes more sense then clutch fork so I see the problem. When I first built the truck I had a 390 with a light duty three speed ( stock trans for the truck ) but I used the stock hydraulic clutch set up with a slave cylinder. I had to have a mount for the slave welded to the bell housing. I don't know of any way to use mechanical linkage in these chassis..
df85732
19
06-14-2017 03:27 AM
Fellenz
02-07-2015 02:49 PM
blatherskite
11-10-2003 04:42 PM
