Go Back   Ford Truck Enthusiasts Forums > Towing Forum > Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers
Sign in using an external account
Register Forgot Password?
Torklift Fortress GasLock - Product Reviewed
Old 09-23-2014, 11:51 PM
C7XR7's Avatar
C7XR7 C7XR7 is offline
C7XR7 is starting off with a positive reputation.
I received the Fortress GasLock from Torklift International to secure my propane tanks and want to tell you about how it works.
What came in the GasLock package;
· U-Bracket
· Lock Handle
· Washer
· Pin Lock
· Decal
· Instructions
Click the image to open in full size.
The first thing I noticed on the instruction booklets front page was the text below the “Fortress Gas Lock” title was about putting a rubber mat in your truck bed and that having a plastic drop in liner would void the warranty. OK, so I think some old text may not have been updated yet for this new product, that is to be expected with new products. On page two and three of the instructions there were 6 steps listed that were about the GasLock so that was good. The parts all look to be very well made, chrome or powder coated and of substantial gauge to perform well as a locking mechanism for the tanks.
The photo (below) is where I will be mounting the new propane tank GasLock.
What I noticed at this stage was the instruction photo shows the lock mounted facing toward what would be the opening in the photo above. The front of the tanks. The instructions also call for the lock to be on the opposite side of the regulator and in my situation that would mean the lock will be on the back side of the tanks and not facing outward. The type of regulator I have on my tanks requires it to be mounted on the front side so it may be manually switched from tank to tank.
Step 1 is to remove the wing nut handle that holds the tanks down – put it away somewhere as you’ll not be using this again.
Step 2 is to install the tank hold down bracket followed by the U-Bracket with the pin lock hole facing away from the regulator side as shown in the photo below. Follow that up with the regulator mount itself so that it lies on top of the U-Bracket.
U-Bracket
Regulator on top of U-Bracket
Step 3a is to install the provided washer on top of the regulator bracket.
Step 3b is to spin on the propane lock handle supplied (this replaces the old wing nut style handle) over the threaded hold down bolt. Tighten everything down and line up the hole in the lock handle with the hole in the U-Bracket and in my case that is to the rear of the tanks. It is in this step that I noticed the bolt that everything mounts to was a tad short, fortunately there were plenty of threads on the lower end of the bolt so that I could adjust it upwards giving me more space and threads on the top to work with.
The other thing I noticed is the lock handle would strike the regulator while being rotated (see photos below) to remedy that I applied light downward pressure on the regulator mount and was able to finish spinning on the lock handle until snug.
Step 4 is to install the Pin Lock through those two holes, one in the bracket and one in the handle and make sure you can engage the lock. As you can see in the photos below, the locking mechanism (pin) has a lot of slack in it in when installed. This allows for the back and forth and up and down movement of the lock through the holes on the U-Bracket and the lock handle. I kept re-reading the instructions because I was sure I missed something and had installed the lock or handle improperly. For a quick fix I cut a small section of automotive vacuum hose and this acted as a spacer/spring allowing the locking mechanism to fit tightly when engaged. One photo is a view from the back and really illustrates the gap and what the small section of vacuum hose does to eliminate the gap.
Step 5 is to test if you can successfully remove the now installed lock and lock handle.
Step 6 is to install your decal.
My observations;
All provided parts look to be of high quality and sturdy enough to provide some security from propane tank theft. Installing the kit will make it difficult enough that a thief would likely pass your set of tanks up for some much more quickly and easily removed.
The lock handle; I think if the handle were in a little more of a “V” shape like the original wingnut styled one I removed from the tank mount there would have been no chance that I would have had trouble with it striking the regulator. I may in fact do this myself with a vice the next time I remove it, it would not take much of a bend. I also don’t believe that V shape would impact the locking function.
I think the loose locking mechanism gives one a perception of the lock being less secure than it really is. I think the installation of a spring where I have the vacuum hose installed or perhaps a more “ratcheting” style of pin lock would better adjust for the varying distances thus removing the slack in the lock.
It was a quick and easy install that requires no special tools.
Jeff.
Old 09-24-2014, 04:11 AM
RV_Tech's Avatar
RV_Tech RV_Tech is offline
RV_Tech has a brilliant futureRV_Tech has a brilliant futureRV_Tech has a brilliant futureRV_Tech has a brilliant futureRV_Tech has a brilliant futureRV_Tech has a brilliant futureRV_Tech has a brilliant futureRV_Tech has a brilliant futureRV_Tech has a brilliant futureRV_Tech has a brilliant futureRV_Tech has a brilliant future
Is the theft of propane tanks a common problem?
Steve
__________________
RVDA/RVIA Master Certified RV Technician
You think you're confused?
2002 F350 Dually, Rhino Liner, Edge Evolution (running in stock mode), 4" exhaust, 6.0 cooler
2010 F150 super cab, box stock, bed slide, ARE bed cover
Old 09-24-2014, 07:35 AM
Chalkie Chalkie is online now
Chalkie is starting off with a positive reputation.
Quote:
Steve
That's what I was wondering. Is this a needed product or a solution searching for a problem to solve.
__________________
You know you live in Colorado if you know where the REAL South Park is.
2008 F-250 6.4 PSD SRW King Ranch on optional 20's, Undercover Tonneau, Line-X,
B&W turnover & Companion slider
2013 40' Infinity 3640RL 5er
Old 09-24-2014, 11:34 AM
seventyseven250's Avatar
seventyseven250 seventyseven250 is online now
seventyseven250 is a splendid one to beholdseventyseven250 is a splendid one to beholdseventyseven250 is a splendid one to beholdseventyseven250 is a splendid one to beholdseventyseven250 is a splendid one to beholdseventyseven250 is a splendid one to beholdseventyseven250 is a splendid one to behold
This is an anti-theft device? I know around here tank theft is not at all common.
__________________
2012 F150 SuperCrew EcoBoost 4x4 XLT/XTR 145" WB 3.31 Axle
Quote:
Originally Posted by Jklnhyd View Post
Holy hell, its not even 9am and you folks are gonna drive me to drink....
Old 09-24-2014, 11:41 AM
RV_Tech's Avatar
Quote:
The only time I have run into it is when the employees at the repo auction sites steal them.
Steve
__________________
Old 09-24-2014, 02:02 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
never seen a tank stolen before. But I suppose it could be.
__________________
Scott-2013 F350 with a lot of tires.
2013 40' 4-slider stoneridge 5th wheel coming in at 15,400; 2015 Lincoln MKC
http://www.ford-trucks.com/guidelines.html
Previous Truck 2008 F250 6.4 with lots of upgrades and a suspension upgrade from Torklift International StableLoads
Old 09-24-2014, 02:10 PM
Tedster9's Avatar
Tedster9 Tedster9 is offline
Tedster9 has much to be proud ofTedster9 has much to be proud ofTedster9 has much to be proud ofTedster9 has much to be proud ofTedster9 has much to be proud ofTedster9 has much to be proud ofTedster9 has much to be proud ofTedster9 has much to be proud ofTedster9 has much to be proud of
In some places anything not nailed down is basically fair game, construction sites have a real problem. All of the stuff is expensive and is readily saleable, too.
__________________
Keep 'er between the ditches.
1964 F-100 292 V8
2009 XLT Ranger 4.0 V6
Old 09-24-2014, 08:23 PM
Not around my home either.
Quote:
Anything can be stolen, the question is, is there any value in what you are stealing. Somehow, propane tanks do not seem too high on the list.
Quote:
Yes, yes, you are correct. My son is a commercial journeyman electrician and stuff is stolen off their work sites with alarming frequency. It is why he will leave none of his personal tools on a site, even in one of those "locked" job site boxes. BUT, the things stolen are high dollar items, like power tools, not a silly propane tank.
So I guess I still have to wonder, is this really something someone would spend money on?
__________________
Old 09-24-2014, 09:12 PM
Tedster9's Avatar
Maybe, whoever is making them figures so. Good way to make a living possibly. The hell with "doing something you love" find out what people need and make some money at it.
The mountain West still has more of a tradition of "leave people's stuff alone" than some places, but.. There's scalawags everywhere. Scrap scroungers, usually heavy meth tweakers I suppose, will cut anything copper for example, to get money. Never mind they stole somebody's outside AC compressor by cutting refrigerant lines. Maybe they get 40 bucks or something? Rain gutters, metal railings, Bronze VFW markers on gravesites - it doesn't matter. Propane tanks? Sure why not.
__________________
1964 F-100 292 V8
Old 09-24-2014, 09:30 PM
Around here, a propane tank is worth about thirty bucks, if that lock is worth more than that, seems like it's cheaper to let someone steal the tank . . .
__________________
Old 09-24-2014, 09:39 PM
Tedster9's Avatar
There's the aggravation factor, the money ain't always the big thing. I had a roomate in the .mil who allowed that he and a buddy used to steal car batteries from parked cars. Would just clip the cables and make off with 'em. Couldn't believe it.
__________________
1964 F-100 292 V8
Old 09-25-2014, 06:59 AM
I'll give you the aggravation factor.
After doing a little research, I would say the locks would be of value IF you were somewhere where theft was an issue. The lock only works on a mount that has a threaded rod (1/2" or 3/8") to hold the bottles down, which seems to be more oriented to TT's with the bottles mounted on the tongue. I could create something on my fiver so that one could be used on the tanks in the side compartments, but I would then need two of them. A new 30 lb. bottle can set you back around $100 and the lock costs $70, so fair enough on the lock to bottle cost ratio.
I guess I am more trusting or naïve (take your pick) but I still do not see gas bottle theft as an issue. I have had gas bottles on or in trailers sitting in front of my house for years without an issue (along with at least 8 other neighbors) and I just can't imagine someone messing with your stuff in a campground.
As to the car batteries, really? Heh, around my home you have to pay to get rid of a used battery unless it is core trade-in on a new one.
__________________
Old 09-25-2014, 07:16 AM
RV_Tech's Avatar
Again one of those things that likely varies with locale and situation. Stealing small stuff is easier. One of the residential campgrounds I service has a wave of thefts last winter where someone came through and stole all the batteries, but no tanks were taken. I think they are just too much work for taking to make sense. Just a lot to cart off perhaps.
In regards to the necessity of many things sold to campers, my thought has always been you could do away with half of the Camping World catalog and do no harm at all. There is just a wide gulf between what folks actually need and what they think they need. We have tubs of stuff we acquired over our years of RVing that we used to think we "needed". Now we can't recall why we bought them.
Steve
__________________
Old 09-25-2014, 10:13 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
And NOW we have to decide do we want to haul them around or build another building out back to fill up with 'stuff'
__________________
People are much more opposed to fur than leather because it's much easier to harass rich women than motorcycle gangs.
13 F350 Platinum 6.7 CCSB , 13 Explorer Sport 3.5 Twin Turbo 365 hp Ecoboost. Gone: 12 MVP Destiny 355RE 5er,12 F250 6.7 CCSB Grey Metallic Lariat w/ Ultimate Pkg,05 Ex 4x4 6L,03 Ex 4x4 6L,02 Ex 4x2 7.3L
Old 10-02-2014, 06:29 PM
Torklift Sheryl's Avatar
Torklift Sheryl Torklift Sheryl is offline
SPONSOR
Torklift Sheryl has a good reputation on FTE.Torklift Sheryl has a good reputation on FTE.
Great recap, Jeff – thanks for the feedback on the propane lock!
Torklift decided to create a solution for our customers in response to several stories of ‘cut and run’ theft where the damage can cost up to $500 - replacing the stolen tanks, slashed regulators, and damage to tank covers. As a way to secure your tanks and deter thieves, we’re hoping to give customer’s peace of mind when it comes to camping.
Fortress Gaslock – propane tank security
Here are some links on recent propane tank thefts reported.
Link - Theft at vacation areas
Link - Travel trailer propane tank theft
Torklift Sheryl
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Similar Threads
Scangauge IA1 readout waaaay too high 11jjonn 6.0L Power Stroke Diesel 2 05-07-2015 07:23 PM
vacuum regulator valve knash0727 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 01-27-2015 02:03 PM
My 70 F250 Camper Special XLT Catch84 1967 - 1972 F-100 & Larger F-Series Trucks 10 10-03-2014 09:34 PM
Restoring Grandpa's '57 F100 - First Truck and First Post '57 Ford F100 Nut 1957 - 1960 F100 & Larger F-Series Trucks 92 08-05-2014 05:39 PM
Starter problem??? Hooie2013 Expedition & Navigator 5 06-24-2013 01:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
