Massive oil temp spike, oil cooler going bad?
Was pulling trailer empty, GCVW was just a hair under 15K, prior I was just under 29K loaded and no issue. Anyway coming back empty with cruise set at around 75mph and I always check the Minimax (set on NO Power) from time to time. All the sudden I notice my EOT is 250, ECT was normal at 209 and Tranny was 189, Can't remember EGT but I wasn't hammering on it.
I never got a warning from the truck and I quickly slowed to 60mph and the temp steadily dropped. After a few miles I was down under 220 and I remained around 70mph and EOT stayed 10-15 degreees over ECT. Had to stop for a minute and both temps came down to the 190's like normal. Got back on the road and everything was normal, ECT and EOT never differed more than 6 degrees and that was going 65mph against a good headwind and a fair grade for 15 miles.
I should mention the Air filter alarm went off at the start of this trip and I did know it was getting close to tripping before hand. Oil was changed about 500 miles ago with 15w40 ( was running 5w40 ), level is good. I have been smelling a little burning oil since the change and I think it is just the little bit that fell out of the filter and right on top of the engine when I changed it. When I got back I blew apart all the radiators/coolers and there is a lot of debris, mainly between radiator and AC condenser.
I thought with the updates I should have gotten an engine shutdown with that kind of a temp difference. Truck was just at the dealer for belt tensioners and some front end work.
Forgot to mention 124K miles been deleted since 100K.
H&S minimax, pulled all the radiators yesterday and got all the crap out from between them. Went out today and the temps fluctuate a lot more than they used to but EOT and ECT never separated more than about 5 after warm up. Yes I put the minimax on after 11B23 came out.
<a href="http://s68.photobucket.com/user/westwoodlands/media/3c110bd6.jpg.html" target="_blank"><img src="http://i68.photobucket.com/albums/i34/westwoodlands/3c110bd6.jpg" border="0" alt=" photo 3c110bd6.jpg"/></a>
I concluded that H&S's base program did not include the 11B23 update. In fact, it was a very old PCM flash that at one point, allowed these trucks to regen in park.
Otto396
28
05-03-2016 09:41 AM
