Seat foam options - Ford Truck Enthusiasts Forums
Seat foam options
Old 09-23-2014, 09:14 AM
ADK49's Avatar
ADK49 ADK49 is offline
ADK49 is starting off with a positive reputation.
Seat foam options
I have been searching the forum for seat options for my 49' and have decided I would like to keep the stock seat. My bench seat frame is in really good shape but the foam needs to be replaced. I have not been able to find any sources for quality foam locally. (unless I want to pay to have it reupholstered, and I would rather do it myself)
Do any of you guys have an online source for quality foam?(or local place that would ship) The places I have found online don't have the best descriptions and I don't really want a couple hundred dollars worth of junk foam.
Old 09-23-2014, 11:28 AM
PHXHawk's Avatar
PHXHawk PHXHawk is offline
PHXHawk is starting off with a positive reputation.
Where are you located?
If we knew where you are, someone could probably come up with a supplier.
Old 09-23-2014, 12:53 PM
ADK49's Avatar
Sorry I thought I had added my location before. I am in Warrensburg, NY. I did speak with a woman who does Marine work who may be able to get some larger sheets of foam. She is checking on how much the minimum order would be though.
Old 09-23-2014, 04:21 PM
1950F2 1950F2 is offline
1950F2 is starting off with a positive reputation.
I got foam for my bench seat from Joann Fabric, you can get different thickness and the blank is big enough to do in one pc. Also you can get batting there to cover springs.
Old 09-23-2014, 04:54 PM
ADK49's Avatar
Quote:
Has the foam held up well? and is it firm enough? I was looking at joann fabric but when I was there all i could find was very soft and I was worried about having a firm enough base.
Old 09-23-2014, 05:13 PM
gerrymoe's Avatar
gerrymoe gerrymoe is offline
gerrymoe is a splendid one to beholdgerrymoe is a splendid one to beholdgerrymoe is a splendid one to beholdgerrymoe is a splendid one to beholdgerrymoe is a splendid one to beholdgerrymoe is a splendid one to beholdgerrymoe is a splendid one to behold
Carl Ferullo
4490 State Route 9
Warrensburg NY 12885
518-623-3811
Warrensburg Car Care LLC
3985 Main St
518-623-2135
Old 09-23-2014, 06:08 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Mid Fifty Home - Mid Fifty F-100 Parts sells seat upholstery foam in several thicknesses. Foam comes in several types and many densities. Most fabric store foam is meant for pillows etc, not for vehicle upholstery. it will likely bunch up, stretch, creep, wrinkle. Make sure you get a type and density for vehicle upholstery, and research the proper way to install it. Typically the springs are covered with a layer of cotton duck, burlap or denim, then the foam with the corners trimmed/sanded to shape (electric carving knife is the tool of choice for trimming foam, followed by smoothing/shaping with a coarse sanding disk used with a light touch). followed by a layer of polyester fiber (quilt lining from the fabric store) extended past the edges of the foam, then a covering of heavyweight muslin,burlap or duck (both layers of fabric should be sewn like a well fitted seat cover to include the sides. so it covers the entire seat and then be whip stitched with twine or hog ringed in place with a little tension to hold the shape and finally the upholstery fabric cover goes over the whole thing. If you have access to a heavy duty sewing machine the surface fabric would be sewn together with all the layers and possibly some additional padding to form the pattern. For seating upholstery you want to use a fabric with a no stretch backing. Grab the fabric with both hands and vigorously try to stretch it in all directions. If it gives or distorts any, pick something else. Most upholstery fabrics can be purchased with or without a stretch resistant backing. That allows the backed fabric to be used on the seating surfaces and the unbacked to be used to cover compound curves like dashboards, consoles, sculptured door panels, headliners etc. where you want the fabric to stretch for shaping.
Drivers side and passenger side seat cushion foam replacement questions RBerry9511 Excursion - King of SUVs 2 09-26-2015 01:47 PM
seat/back foam cushions or new seats AppocAlexx Excursion - King of SUVs 12 03-03-2015 03:32 AM
Recovering seat need new padding flipklos 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 02-16-2015 01:02 AM
Bench seat repair question Dorsai 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 11-24-2014 08:06 PM
Thickness of seat foam abe 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 11-02-2014 07:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
