need advise on a turbo wheel and benefits of ebpv delete
Old 09-22-2014, 08:22 PM
rollin_coal's Avatar
rollin_coal
rollin_coal is offline
Got a 02 7.3 cc lb. Afe stage 2 intake,4in turbo back exhaust, edge cs with juice attitude. Looking to upgrade the turbo wheel and also whats the pros/cons of ebpv delete? Was thinking the wicked wheel 2 but is that the best one? I also have a cfm
intake manifold I haven't put on yet, not sure if its worth it but it came with the truck.
Old 09-22-2014, 08:34 PM
F350-6's Avatar
F350-6
F350-6 is offline
Welcome to FTE. The EBPV delete is the thing you'll likely notice the least benefit from unless your EBPV is currently leaking oil The WW2 or a ported housing would be the top of my list to deal with surge issues.
Old 09-22-2014, 10:42 PM
rollin_coal
I cant even remember what the ebpv does lol, its been awhile, but no mine doesn't leak, my trucks in real good shape for a 02 with only 113k.
is the wheel better than the ported housing, ive read you dont do both since they both fix the same issue.im all for any hp or tq gains I can get or faster boost. I also forgot to mention I have a banks big head waste gate if that matters. What about these boost foolers ive seen. I've basically got the truck the way it is besides changing out the air intake for the afe, It had a low quality one before.basically looking for some good lower budget mods to do while I recover from buying the truck.
Old 09-23-2014, 08:16 PM
F350-6's Avatar
F350-6
F350-6 is offline
It closes a flap to increase back pressure coming out of the turbo to aid in warm up or keeping the engine warm at idle when it's really cold out.
They both accomplish similar things using slightly different methods. The wheel is cheaper, which is why it's so popular. It could be argued the ported housing is better, but as long as the mod cures any surge issue, it really doesn't matter which one you use.
Doesn't matter. Won't hurt anything at all.
Great mod if you're having trouble with overboost codes and it defueling the engine when you get on it. If you can't run enough boost , or your programming is set to ignore an overboost, then it really isn't needed.
There are several kits available. Some expensive, some cheap, and DIY instructions are available if you'd rather go that route. It's really not hard to do and you can get all the parts at the local hardware store. Just watch the pricing. Sometimes it's cheaper to just buy a kit from someone else if you can't get the parts cheap enough.
Old 09-23-2014, 08:34 PM
white Buffalo's Avatar
white Buffalo
white Buffalo is offline
Like always Chris - great explanation
Riffraff makes a nice boost fooler with a very clean setup:
OCR - Overboost Code Regulator - Riffraff Diesel Performance
Old 09-24-2014, 04:58 AM
River19's Avatar
River19
River19 is offline
This was the easiest thing to install and very effective......
Old 09-24-2014, 09:35 PM
rollin_coal
Good info thanks. Should I decide to spend more money is there a good turbo that I should upgrade to thats not insanely expensive and would I need to do a fuel upgrade? Also on the fuel subject is there any good budget friendly fuel upgrades?
Old 09-24-2014, 09:44 PM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
X2! A great item! Easy install. Before installing this, every time I hit 24lbs of boost it would defuel and drop to 12lbs of boost. Now I can hit 30lbs no problem with a stock turbo. Next will be a 38R!!!
Old 09-24-2014, 10:19 PM
rollin_coal
Looks like a good deal, anyone running that riff raff fuel rail cross over?
Old 09-24-2014, 10:55 PM
cjgray1974's Avatar
cjgray1974
cjgray1974 is offline
I have one on my F350, and just got one for my 250 I'm putting on along with a bunch of other stuff. It does quiet the injectors some but I didn't notice it as much as some have. Another thing to think about is gauges, especially if you are gonna boost the HP. EGT, tranny temp, boost, and fuel pressure can really help you make your motor last. Here's a good thread about getting your truck to 100%.
https://www.ford-trucks.com/forums/1...his-first.html
Old 09-24-2014, 11:13 PM
rollin_coal
I have the edge cs for gauges
Old 09-25-2014, 05:10 AM
Tugly's Avatar
Tugly
Tugly is offline
Since you have OBDII gauges, here are the 4 you don't have - but want: Left EGT, Right EGT, Fuel Pressure, Boost. I have OBDII, but the boost fooler means I just use it for looking at the small boost. The big boost gauge is on the dash. I have a strange setup - I refuse to have more than three gauges on the dash, so I converted my Fuel Pressure gauge to a FP/boost gauge.
Old 09-25-2014, 10:17 AM
holeshotwalt's Avatar
holeshotwalt
holeshotwalt is offline
reasonable price, effective upgrades
I did an EBPV delete pedestal to eliminate leaks AND gutted the valve to clear the restriction in the exhaust. Then an oil crossover line (HPX) and the FRX which combined really quieted things down and gave better throttle response. The injectors will live longer, too! IMHO, Just getting the intake and exhaust cleared out, with a WW2 and the rest close to what you have is the best, cheapest gains you're gonna get. Next up is big money for fuel supply ($600), turbo ($1400), big oil (900), injectors($1500- 2500)!
Good luck, isn't this fun?!
flatbeder
17
11-05-2009 10:41 AM
a-rod
03-03-2008 01:50 PM
STROKIN'IT7.3
01-16-2008 02:31 PM
Flinno18
06-21-2005 04:35 PM
BagStroke
06-25-2004 01:44 PM
Quick Reply: need advise on a turbo wheel and benefits of ebpv delete
