bleeding procedure for rear ABS
Old 09-25-2014, 04:25 AM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
The RABS doesn't compare the axle speed to anything - it has to look at decel rate and speed to sense lockup. I believe the RABS is independent of and functions the same no matter the rest of the powertrain.
Old 09-25-2014, 04:41 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
So, it's only looking at the speed (pulses) of the tone ring and doesn't compare to actual road speed in any way?
I guess I will just disable it.
Old 09-25-2014, 09:28 AM
Island Time's Avatar
Island Time
Island Time is offline
Implying it has it's own integral decelerometer in it that was accurate enough to provide that capability. I'm surprised that they had tech accurate enough at a price point to make it economical to do 25 years ago. I'm not saying it doesn't work that way, I'm saying I'm really impressed that they did it
Old 09-26-2014, 04:28 AM
EPNCSU2006's Avatar
EPNCSU2006
No accelerometer. It's all based on rate of change of the rear axle speed. There has to be a programmed rate of change curve where if the actual rate of change is above the limit, lockup is inferred and brake pressure is modulated until ROC is back above the threshold. For example if rear wheelspeed drops from 50mph to 30mph in 1/2 second and based on a programmed maximum deceleration rate the same speed reduction for the same speed change is 2 seconds, the computer knows that the wheels are beginning to lock and reduces line pressure until speed goes back up above the curve.
Old 09-26-2014, 10:13 AM
Island Time
That's a pretty simple approach, and probably a lot more reliable. Smart cookies those engineers.
mjbll
1997 - 2003 F150
05-21-2009 08:08 AM
wynntown marshal
1978 - 1996 Big Bronco
09-18-2008 01:02 PM
ghunt
22
09-10-2008 08:14 PM
maflinchbaugh
General Automotive Discussion
01-02-2006 10:57 AM
bigdaddyII
1997 - 2003 F150
04-27-2005 05:21 PM
Quick Reply: bleeding procedure for rear ABS
