99 f350 oil leak, won't start - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-22-2014, 12:09 PM
Garrettperry1 Garrettperry1 is offline
Garrettperry1 is starting off with a positive reputation.
I found today that I have an oil leak. I started my truck this morning and it kind of sputtered on like it didn't want to start. I drove maybe a half mile before it began to sputter out like I was out of fuel even though I had just under a half tank. When I pulled over I noticed that I had no engine oil, so I filled it back up and it still won't start, it will turnover though.
Old 09-22-2014, 12:22 PM
Pikachu's Avatar
Pikachu Pikachu is offline
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
The injection system uses engine oil for hydraulic pressure. There is a line that goes to each head to supply it. If one of those lines blew, you aren't going to get it started until the line is replaced. If it's leaking elsewhere and the high pressure pump ran out of oil, it's going to take a pretty fair amount of cranking to get it to start. The oil rails in the heads will have air in them that needs to be forced out.
Old 09-22-2014, 12:27 PM
Will I flood the engine by continuing to crank
Old 09-22-2014, 01:01 PM
Pikachu's Avatar
No. There's really no such thing as flooding a diesel by cranking it. Until the hydraulic pressure comes up to at least 500 psi, the injectors will not be fired. That's controlled by the PCM. Crank for 15-20 seconds, let the starter recover for a minute or two. Repeat that process; it could take upwards of 5 cycles to get it to start. If it doesn't start by about the tenth cycle, let us know.
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
Pull out the plug for the hpop reservoir. See if it has oil in it. You can fill the reservoir which should help to get it started. The low pressure oil pump has to push oil into that res so the high pressure oil pump can feed the injectors.
Old 09-22-2014, 01:52 PM
The battery died before I could start it, a friend of mine said it could possibly be water in the fuel, so I drained the water separator is what he called it and went to crank it and it wouldn't turn over so I am going to get a charge on the battery and try again. I got it to turnover a solid three or four times before it slowed and wouldn't turn
Old 09-22-2014, 01:54 PM
I live on the beach so the reasoning is that it has been raining off and on for the past few days and the temperature has been fluctuating between 70-100 degrees coupled with it sitting or being driven less than five miles a day for the past week or so
SOLVED 2002 for excursion no start help radmacks 1999 - 2003 7.3L Power Stroke Diesel 3 02-23-2016 01:19 PM
Random sputter, then stall. sniperscoutwill 1987 - 1996 F150 & Larger F-Series Trucks 3 02-18-2016 10:56 PM
1999 F-250 diesel (7.3) cranks but wont start Hawaiianbobby 1999 - 2003 7.3L Power Stroke Diesel 6 09-21-2015 09:58 PM
351w won't stay running Gear619 1987 - 1996 F150 & Larger F-Series Trucks 4 05-12-2015 08:54 AM
96 f350 died while driving won't start Tinker2 1994.5 - 1997 7.3L Power Stroke Diesel 30 04-29-2010 09:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
