Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 09-20-2014, 07:19 PM
octaneforce's Avatar
octaneforce octaneforce is offline
octaneforce is starting off with a positive reputation.
Bucking when hot
When my truck is cold it runs perfectly. As soon as it gets to operating tempurature it develops a pretty bad miss. It idles rough and bucks terribly at low rpms. I dont think my egr is hung up because it still does it when i remove the vac hose. the egr valve is about 2 years old. Cap, rotor, plugs, and wires are also in the 2 year range. No codes. What else could make it run cruddy when its warm?
Old 09-22-2014, 10:29 AM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to behold
Ignition Control Module (ICM), PIP (stator), coil
All three are common causes of your described symptom.
You can have the ICM tested, the PIP is a little trickier. Coil can be swapped.
__________________
2013 Ford Taurus Limited 3.5L
2006 Ford Mustang GT 5-speed 3v 4.6L
rla2005@yahoo.com
Randy A | Central Illinois
Old 09-24-2014, 10:58 AM
TorqueKing's Avatar
TorqueKing TorqueKing is offline
TorqueKing is gaining momentum as a positive member of FTE.
Relevant to the 4.9L I-6:
It would probably be worth your time to change out the TB gasket. Mine was sucked all the way into the contours of the idle air passages. Here's a video that walked me through it. It's a very inexpensive fix, but you'll make a mess cleaning out your old throttle body:
__________________
John F. Daly III
'77 F-100 LWB, 100% Aftermarket 302-R.I.P. (Stolen)
'95 F-150 SWB, 300 I-6 Now with 300,000+ miles!
US Navy Seabees- "Can Do" since '42
Old 09-27-2014, 05:42 PM
I cleaned the throttle body and replaced the gasket with no change in behavior. icm and stator? is the stator inside the dizzy? wheres the icm? coil was replaced with my last tune up but I could swap another one in being that they are so cheap.
__________________
1992 f150 xlt 4x2 5 speed Inline 300 3.55LS
Old Today, 01:57 PM
TorqueKing's Avatar
Gas Filter is next. I think there's a very good chance this will make it right.
__________________
John F. Daly III
Old Today, 02:31 PM
rla2005's Avatar
Quote:
Yes, the stator (PIP) is inside the distributor
For reference: Stator
The Ignition Control Module (ICM) is located on the distributor ('91 and earlier) or mounted on a heat sink near the driver side hood hinge ('92 and later).
__________________
rla2005@yahoo.com
Old Today, 06:53 PM
ohh I actually did the icm once on this truck. its on the fender on my 92 like you said. looks like im gonna be fooling with the dizzy if the fuel filter doesn't help. ill look in the book how to test the icm.
__________________
Old Today, 08:48 PM
TorqueKing's Avatar
I don't know of any reasons why ignition system performance would fade when the engine gets hot. You can always check for spark with a spark tester, which is basically a dummy spark plug that you ground with a clip and a see-through window that makes it easy to watch for spark. If your truck starts and runs at all then the test is redundant. Do you have any CEL codes? That Hall Effect sensor inside the distributor is a real pain to change, and won't always be fixed by buying a new distributor from the parts house. In my experience, they cause a no-start or sudden failure condition rather than fade with heat. If the gas filter doesn't make it right, it's worth your time to do a solid diagnostic with a good multimeter (Fluke) and an oscilloscope. Hopefully it doesn't come to that- just did mine about 6 months ago!
Old Today, 09:48 PM
carguy94 carguy94 is offline
carguy94 is starting off with a positive reputation.
don't mean to but in but as mentioned you need to pull the codes again and do you have a catalytic converter on your truck what do you have as far as tools like a volt meter vacuum gauge or a back pressure gauge things of the nature.
Old Today, 09:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Confused Regulator1988 6.0L Power Stroke Diesel 6 01-26-2013 03:07 PM
94 Ranger running bad johnsmart Ranger & B-Series 7 09-05-2004 06:31 PM
Any problems with a removed EGR valve? Petiboy Aerostar 2 11-05-2003 02:55 PM
code 31-egr sensor and valve ?'s oldford2 Electrical Systems/Wiring 22 04-27-2003 07:26 PM
rough engine after warm chimneydoc Bronco II 3 05-12-2001 10:55 AM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
