removed distributor and half a gasket fell out
Old 09-20-2014, 01:19 PM
mgargiullo's Avatar
mgargiullo
mgargiullo is offline
Did ford use a gasket between the distributor and the block on the 223?
Old 09-20-2014, 06:36 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Short answer is Yes
Old 09-20-2014, 07:37 PM
59f100mike's Avatar
59f100mike
59f100mike is offline
Whats the long answer?
Old 09-20-2014, 08:15 PM
spurredon's Avatar
spurredon
spurredon is offline
It was a fairly thin paper type!
Old 09-21-2014, 07:34 AM
hiball3985's Avatar
hiball3985
hiball3985 is offline
There hasn't been one on mine in the past 30 years and haven't had an oil leak problem.
Old 09-21-2014, 12:58 PM
theodore/teddy
Refyred
HA
I think Spuredon , Hiball covered the long Answer. But if you feel the need, the part number would be one of these two choices depending.
Old 09-21-2014, 02:13 PM
Damifiknow's Avatar
Damifiknow
Damifiknow is offline
I think the dizzy from the Inline 300 I installed had an "O" ring. Question is what happened to 2nd half of your gasket?
Old 09-21-2014, 05:49 PM
spurredon's Avatar
spurredon
The gear on the cam shaft would have very little trouble taking care of it if it went in but I would sooner think it went out and down the road some place.
Old 09-23-2014, 07:17 AM
mgargiullo's Avatar
mgargiullo
That's the likely answer. Need to replace the vacuum advance as well... Once that arrives, I guess I'll pull it again and make a thin gasket for it.
Old 09-24-2014, 07:51 AM
1960fordf350's Avatar
1960fordf350
1960fordf350 is offline
My distributor locked up on me last week. Ordered a rebuilt from autozone. $60 with no core charge. I got it yesterday. Came from Mexico, looks like a brand new unit. It has the o-ring on it like a newer distributor, so no gasket. Hopefully I will get to put it in tomorrow.
Old 09-24-2014, 01:48 PM
hiball3985's Avatar
hiball3985
Please explain the distributor locking up, that just doesn't seem normal, The older they get the more the bushings wear an increase clearance. If it did lock up the drive gear pin would shear. Can you post a picture of the new one with an Oring?
Old 09-27-2014, 08:10 AM
1960fordf350
When it locked up it did shear the pin. It turns out I was tightening the lockdown to tight. With that rubber gasket, it sets the depth also. The gear was actually rubbing the block and pushing upward. The new distributor is actually 1/8 inch shorter on shaft length, also raising the gear. The old distributor shaft comes loose if I pull down on it. If I push up on it will turning it, it locks up. Even if I wasn't too tight, the drive gear cut pushes upward on the shaft as it turns. No pics, I already have it in the truck.
So, in conclusion, I'd measure my distances to make sure you don't waste a distributor like I did.
Old 09-28-2014, 10:27 AM
hiball3985's Avatar
hiball3985
There seems to be a little confusion. This post was about a 223 distributor and I think you are talking about a Yblock. Thats why I questioned the Oring..
Old 10-07-2014, 09:31 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
FAA-12143-A .. Distributor Base Gasket / Obsolete
1952/53 215 I-6 / 1954/64 223 I-6.
B9TF-12143-A .. Distributor Base Gasket-Rubber / Obsolete
1957/59 272 / 1957/64 292.
Old 10-11-2014, 10:29 AM
mgargiullo's Avatar
mgargiullo
I ended up tracing the area and making one to fit.
Quick Reply: removed distributor and half a gasket fell out
