Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 09-19-2014, 08:27 PM
77f2504by4's Avatar
77f2504by4 77f2504by4 is offline
77f2504by4 is gaining momentum as a positive member of FTE.
weird brake problem...
Hi all,
I had something happen today that seems to defy logic....
So this morning I made a dump run in my 97 f250hd 4x4 351 5 speed... while I was in the bed dumping all the junk out of it I noticed a faint smell of brakes, that smell you get when your brakes are dragging. I didn't think to much of it, because there was another guy next to me driving a junker, and I just figured out was so faint it must be him.
A few hours later the passenger side rear brakes locked up on me. So I pulled it apart expecting to see a broken spring, or something. There was nothing out of place, except that the e brake lever was partially engaged. Now I'm the only person who drives this truck and I know for a fact that I didn't touch the e brake pedal. In fact, when the brakes locked up I tried pulling the e brake release and it was already all the way up.
So my question is, what could cause the e brake to engage on one side suddenly, when the pedal wasn't touched? After pulling the drums off I found out what the problem was, but what caused the problem? I still have it all apart, and I don't want to put it back together again until I figure this out!
Thanks for any help!
Old 09-19-2014, 08:36 PM
LeoJr LeoJr is offline
LeoJr is starting off with a positive reputation.
I installed some side steps. 2 years later (I don't use them very often) I set the emergency brakes as we were pushing a skid of sod farther on the trailer and I didn't want all that pushing going against the auto trans parking pawl. I released the E brake and heading home. I knew 3 skids of sod was heavy but it was pulling really heavy. Turns out the E brake cable caught on the edge of a side step bracket and wasn't releasing one wheel completely.
Maybe the heavier than normal load caused the truck to sag and the cable is catching or pulling on something you did awhile ago?
__________________
*1996 F250 crew cab/short bed, 4x4, auto PSD*Looking for gray 40/20/40 seats, I have a dirty set of blue I'd trade *stainless window vents *3/8" shim under the drive shaft carrier bearing has eliminated the take-off shudder *remote door locks work with engine running mod.
Link to my D60 refurb and OBS swap thread Link to my OBS air vent R&R thread Link to my grab handle install
Old 09-19-2014, 08:55 PM
77f2504by4's Avatar
Hmm... I'll look in the morning if there is something weird going on like that, but I haven't done anything new to the truck at all. And the dump load was nothing to write home about, the truck was barely loaded at all.
Old 09-19-2014, 09:28 PM
SteelHorse4x4's Avatar
SteelHorse4x4 SteelHorse4x4 is offline
SteelHorse4x4 is starting off with a positive reputation.
Could have a partially broken return spring on your e brake cables also. That and old cables could cause a slight drag, and as we know that's all it takes.
__________________
1994 FlareSide SC 5.8 4x4 E4od LSD(Frt&Rear)
Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy; its inherent virtue is the equal sharing of misery. (Winston Churchill)
Old 09-19-2014, 09:38 PM
77f2504by4's Avatar
Quote:
maybe, thats something i'll look at.
what i dont understand is why it suddenly happened and i havent used the e brake at all since april when i got my sticker...
i could see this happening if i had used the e brake, but it has always been a problem on the other side of the truck, so i go out of my way to not use it.
__________________
Untill next time, I leave you with these words of wisdom...
NOTE TO ALL PREVIOUS OWNERS: STOP IT!!!
Old 09-19-2014, 09:48 PM
New cables are only what? 20 something each? replace them and then use the e brake occasionally so it doesn't freeze up. Sitting and not being used much is one of the hardest things on our old girls.
__________________
Old 09-20-2014, 03:58 AM
Pit Crew's Avatar
Pit Crew Pit Crew is offline
Pit Crew is gaining momentum as a positive member of FTE.
Maybe it got snaged on something at the dump?
Old 09-20-2014, 07:27 AM
77f2504by4's Avatar
i just looked at it again, no such luck on it being stuck on something...
the local dump is all paved, so i would have noticed running something over.
i plan on replacing the cables, but i just don't want this to happen again. there is nothing i hate more than having to take something apart twice, because i didn't fix the problem.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
bad brake booster? |WYG|SS 1987 - 1996 F150 & Larger F-Series Trucks 3 09-20-2011 09:42 PM
Brake problem. Possibly RABS?? hoss khaos 1987 - 1996 F150 & Larger F-Series Trucks 0 08-24-2011 08:33 PM
Interesting Brake/Transmission/4WD/? Problem TMF89 2004 - 2008 F150 11 08-18-2011 10:55 PM
New Brakes smell like they are getting too hot csangster Brakes, Steering, Suspension, Tires, & Wheels 6 09-01-2008 10:27 AM
Emergency brakes are killing me (dragging problem) G2IC_Wraith Ranger & B-Series 6 05-04-2007 08:03 PM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
