10 ply tires on a F150....
#31
Wow, you just go around arguing nonsense just to argue nonsense don't you? The point is the reverse of your nonsense, a wider and/or larger diameter tire needs less pressure to carry the same weight, conversely the same size tire can be rated to carry more weight if the max pressure is higher. Once again though, you've latched onto the most irrelevant aspect of a thread, weight rating is a minor aspect of the OPs needs.
Calm down. It's not nonsense. I could say, "Wow. You really like posting a bunch of misinformation!"
Doesn't matter what the tire is, two different-sized tires at the same pressure, with the same load on them, will have the same contact size. Wider tires do worse in snow and water because they have farther to flush the snow or water out from under themselves. The contact is WIDER, but still the same AREA as a narrower tire with the same pressure and load.
Goes back to controlling those variables for an apples-to-apples comparison...
Jason
Jason
#33
I'm running 10 ply 235/85R16's on my F150. I keep the tires inflated as per the sticker on the door. When I'm loaded up to go hunting or camping I bump them up to 50ish, depending on how much weight I'm carrying. Once empty I drop the pressure down again.
I have a highway tread as I don't really go "off roading." Mostly just gravel or shale roads when hunting/camping. The rest is all pavement. I have about 15,000 K on them now and I'm happy with how they perform and how they are holding up.
#34
Can you post some pictures please?
#35
Jason
Jason
All this aside except as mentioned by Jason, is why I in general am an advocate of leaning towards a taller and narrower tire. A tall narrow tire that can conform/flex without damage and handle rather high pressure is a very versatile tire. At higher pressures they have low rolling resistance, can handle heavy weight and penetrate water, snow, mud etc to get traction on the under surface. At lower pressures they make for a large long contact patch to float, conform very well to absorb surface shapes to both get traction and make for a smooth ride. I put my money where my mouth is, on my daily/everything truck(F350) I roll a 37/12.5 mud tire with a 65psi/3970lb max. If I could find a light truck tire(can conform) in a 37/10.5(or so) with a 80psi(or higher) max I'd roll that, but I can't. Everything "more" get's wider, or is a heavy duty(commercial truck) tire that can't conform or handle light weight well. There is a 39.5/13.5 65PSi/4080lb tire I might go with next time.
#36
#37
#38
on
The sticker on your door is not meant to be used for any other tire size than what it says. 50 psi should be close to the unloaded minimum you should run on load range E tires. Running less than that places you at a higher risk of blowing out a sidewall. Even though you just have a half ton, you should be running about 45 psi minimum. 55 is the lowest I ever go on mine, and that is in the fall for hunting and driving in fields only.
#39
In the real world we call what you're talking about flat/overloaded tires that will quickly wear out, overheat, and/or blow. In the real world we have weight ratings and max/min pressures. Yeah what your saying has merit in the reverse if for example you put semi tires on a F150, then yeah you have a VERY small contact patch. Or has merit off roading where you are going slow and using tires designed to deform with very low pressure. But to just suggest that an overloaded or under pressure tire will just have a bigger contact patch and be fine is VERY dangerous to everyone on the road.
The math doesn't care, but the tire does, the way he's stating it is very dangerous logic for someone that may be inclined to cut corners and/or doesn't understand the risks.
My only point was that contact size is not an easily measured quantity, but it is calculated fairly quickly from two quantities that are pretty easy to measure--tire pressure and load on each tire.
So, if you had two tires at 50 PSI and 1000 lbs on them, one a 235 width and one a 300 width, which will do better in rain and snow? it's not based on contact area, but the width of the tire--they both have the same contact area with the ground.
I tend to prefer higher-ply tires that can hold more pressure, thus allow for a smaller contact area, better mileage, longer wear, even though it does sacrifice some ride comfort.
Jason
#40
#41
I have the pictures of my tires on Photobucket but I have no idea how to put them here. I can probably put one at a time but for more than that I don't know what to do. Frustrated since the so called "upgrade" on Photobucket.
I understand what is being said here about tire pressure, I just don't necessarily agree with it. I have used my truck in 38 (100) degree weather and have never had any tire become more than just slightly warm to the touch. I'm not concerned with sidewall flex generating too much heat with my truck empty. As mentioned earlier, when loaded I increase tire pressure.
#42
#43
#44
I like them a lot. They are quieter on the highway than my old 15 inch tires and they inspire confidence when I'm driving over some of the crushed shale used to cover the roads where I sometimes like to hunt (no flat tires since I started using them on, what can only be described as, little tiny shards of glass designed to look like pointy rocks )
Incidently they have the mountain and snowflake symbol on them so they are designed for extreme weather. They are great on dry pavement, in snow, rain and on gravel. Not so great on ice. Partly, I think, because my truck is too light to really press the tread into the surface for what little traction is available on ice. I run them all year and, even though they were expensive, I am very happy with them.
#45
I bought them for the M+S rating too.
I'm glad you like them on your truck, and you find them tough enough for the road surface.
Interested in your comment about them being expensive.
The size and rating I bought were were only $242 a pair, delivered!
It didn't seem bad. (I do my own mount and balance at my friends garage)
