Blown head gasket
Old 09-18-2014, 07:18 PM
Mattb60's Avatar
Mattb60
Mattb60 is offline
Blown head gasket
So i found out today that spiking temps that I hoped were water pump are in fact blown head gasket.
Due to a conspiracy of circumstances I am going to have to have this fixed at the dealership.
HELP
I know I want to do head studs. I have to order these and take them.
Who is the best source ?
What else would you do while it is in for this ?
Old 09-18-2014, 08:26 PM
cheezit's Avatar
cheezit
cheezit is offline
Stc fitting, dummy plugs ,stand pipes, fuel pressure spring.
Old 09-19-2014, 05:19 AM
Mattb60's Avatar
Mattb60
Mattb60 is offline
Thanks Cheezit !
My mechanic mentioned doing a new oil cooler as well out of concern that the one we just did could have ruptured due to high pressures.
Worth doing ?
Aftermarket or oem ? PPE ?
Old 09-19-2014, 06:16 AM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
Do the 04 engines have the stc fittings?
Old 09-19-2014, 06:22 AM
2006powerstroke90's Avatar
2006powerstroke90
2006powerstroke90 is offline
No.
I would do an oil cooler as well.....personally along with everything cheezit mentioned.
I would go to XDP for the studs....I had them in one day w/free shipping and they were the the cheapest @ 413 everywhere else I looked they were 425++
Old 09-19-2014, 07:31 AM
Super Duty Service's Avatar
Super Duty Service
Super Duty Service is offline
Former Vendor
I would throw a couple hundred on a y pipe. How many miles on it? There should be no labor, just the part. Maybe they'd let you ship it to Josh and have the bellows done.
Glow plugs n wires
If its an 04,, I've got pics on here somewhere of a hpop cover I grinded to give the discharge tube more clearance. Doesn't take much.
6.4 push tubes
Old 09-19-2014, 07:56 AM
Mattb60's Avatar
Mattb60
Mattb60 is offline
Guys, yall are awesome. Thank you!
For an 05 Excursion will i have stc fittings ?
Should I do the ppe oil cooler from XDP when I get the studs or go back with OEM .
Old 09-19-2014, 08:18 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
It depends on when yours was built. Mine has a 2005 engine, but yours may have an '04 engine.
If your sticker on the passengerside valve cover is yellow, it's a 2005 engine.
Old 09-19-2014, 02:09 PM
ves83's Avatar
ves83
ves83 is offline
I called the local stealership here to get a quote and they told me $3300 for studs,gaskets,dummy plugs, standpipes, STC HPOP fittings, and I have everything this was just for the labor
Old 09-19-2014, 10:55 PM
Restlesswildman's Avatar
Restlesswildman
Restlesswildman is offline
Man I would say that is high for labor only!
Two shops I had quote me for the same(studs, gaskets, head work, oil cooler, EGR delete) were between 1200-1800 for labor if I supplied parts. 2700-3200 for labor and parts.
Old 09-19-2014, 11:01 PM
cheezit's Avatar
cheezit
cheezit is offline
At a shop that uses a matrix thats about right. Aprox $117. An hour. Seems fair dealer pricing. But matrix is robbery
Old 09-20-2014, 06:39 AM
2006powerstroke90
When I looked it up in all data just for head gaskets im pretty sure the labor was 20HRS just for the head gaskets, but they shouldn't be charging you much more for the STC fitting as the dummy plugs and blue spring are pretty much right there!!
Old 09-20-2014, 08:59 AM
cheezit's Avatar
cheezit
cheezit is offline
Standard billing for it is 25 hours.
Old 09-20-2014, 09:14 AM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
How many were you able to knock out in a day when you at the dealership?
Old 09-20-2014, 09:19 AM
zrt600guy's Avatar
zrt600guy
zrt600guy is offline
Originally Posted by 2006powerstroke90
No.
I got the arp studs for $389.99 with free shipping thru Modular Motorsports (805)383-4130. They were the best price I could find.
Quick Reply: Blown head gasket
